PDK Tranny Oil Job - 981
I have been Googling and YouTubing for some solid info on replacing the tranny oil on a 981 PDK car. What I've found is sort of helpful...but not 100%. Any of you guys familiar? Some videos seem to indicate it's just a drain and re-fill and others show a pan that you drop and change a filter??? I did a drain and re-fill in my 986 Boxster...but never ran into dropping a pan or replacing a filter. Much appreciated with any experience you've had.
Gear oil is easy: https://rennlist.com/forums/987-981-...-981s-pdk.html
Clutch side of the assembly is more difficult, and should probably use PIWIS to set the level just right.
Location: On a pygmy pony over by the dental floss bush
Here's some reading for you right here on RL. Several threads and posts on the topic.
https://rennlist.com/forums/987-981-...l#post15172162
