momentary check engine light...
I started my 2.7 2008 Cayman today (cold) and drove for about 3-4 minutes when the check engine light came on for about 5 seconds and then went out. I noticed no difference in the way the car normally runs which is very good. I continued with a few errands, restarting the engine several times with no more check engine light nor anything but a normal running engine. The temp was about 40 degrees F and a little dampness in the air. Read the manual and it only seems to address flashing check engine lights or steady check engine light. Thoughts??? I plan on taking it to my indy shop tomorrow to read a stored code if any. Car has 113,000 miles on it and is serviced regularly.
Maybe the battery was delivering low for a bit if it was cold and hadn't been started in a while.
It could be just about anything. Let us know what the stored or pending codes are.
Though if it was a momentary misfire or something, pending codes may have cleared themselves after a few drive cycles.
