Does the CTEK cig light charger work or do I need to get the Porsche one?
Hello
I ordered the CTEK MXS 5.0 battery charger and want to plug it into the cig lighter on my 2006 Cayman S. There Porsche Charge-o-mat is ridiculously expensive so I ordered a CTEK version. Does this work?
This one
Thank you for your help.
This one
Not in MA anymore
I've been using "Battery Tender" chargers for years (cig lighter plugin configuration) with excellent results.
Matt
Matt
Thanks! I will update you on the state of the battery tomorrow
Also, I didn't prepare for hibernation properly, so the car has been sitting at 1/3rd fuel for a couple of weeks now. Summer tires are mounted. Is condensation in the gas tank a problem? Temperature in my garage is rather low, temperatures outside are 32 - 40 Fahrenheit / 0 - 5 Celsius.
Would you take the car for a drive to refuel or does this damage the summer tires?
Apologies for asking so many questions, it's my first winter with the car and I forgot to prepare for hibernation due to university exams.
Since the worst of winter is yet to come, it won't hurt to prep the car properly for hibernation. If the road conditions allow (i.e. no salt), pick a relatively warm day (about 40F) and drive it until the car gets to the operating temps (oil temp 190F+) to burn off condensation. Pick up a bottle of fuel stabilizer on your way to the gas station, fill up the tank, add the stabilizer and drive home. Inflate the tires to 50 psi, hook up the CTEK, put a cover on and you are done. Regarding your concern about possibly damaging your summer tires by driving in the cold, the following is what Michelin has to say:
Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels or using them to support, roll or drive a vehicle.
