Does the CTEK cig light charger work or do I need to get the Porsche one?
Since the worst of winter is yet to come, it won't hurt to prep the car properly for hibernation. If the road conditions allow (i.e. no salt), pick a relatively warm day (about 40F) and drive it until the car gets to the operating temps (oil temp 190F+) to burn off condensation. Pick up a bottle of fuel stabilizer on your way to the gas station, fill up the tank, add the stabilizer and drive home. Inflate the tires to 50 psi, hook up the CTEK, put a cover on and you are done. Regarding your concern about possibly damaging your summer tires by driving in the cold, the following is what Michelin has to say:
Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels or using them to support, roll or drive a vehicle.
Do you keep the CTEK charger in the car (footmat) or outside because it develops heat?
Our streets have been salted quite a bit this week, how do you ensure that there is no more of it on the street? Does it go away at a certain temperature or when it rains?
Thank you for your help, Rennlist is truly the best
You need to wait for a good soaking rain for the salt to get washed away. I would rather keep the car with 1/3 of tank than driving it on salted roads.
Thanks, I'll wait then. Does the charger get very hot? If not, I'd rather leave it inside, otherwise our cat is gonna play with it
It may get warm to the touch, NOT hot. You could probably leave in foot well. Sit it on something heat resistant - (diner plate?). I leave it outside the car so I can monitor that it's functioning okay.
BTW, I use a Battery Tender. Just as good as a CTEK, but less expensive.
I just checked mine and it wasn't even warm to touch. I have the CTEK MUS 4.3 and it's been connected since early December. I know it's working fine since all the proper lights are on.
Driving my first Porsche through the Swiss Alps
Not a battery minder issue, but, Keep watch if you put a cover on your car. In an unheated garage, there is the problem of condensation beneath the cover with a warm spell after a cold period. Happened to us.
Thanks a lot, I was not aware of that! What happened to the paint? At the moment, I put a small blanket on the hood amd top because my cat sleeps on it but no full cover.
No damage, just moisture. Took the cover off until everything in the garage was dry, then put it back on when it got cold. Off again now with the storm and rain this morning. We’ll put it back tomorrow.
Here's a recent notice from Suncoast about the need on some models to make sure to lock the doors when the car is on the tender, otherwise risk the cigarette socket becoming disabled.
