New Odyssey Battery (925) in 987.2 Spyder
Ok so I'm installing a 925 Odyssey in my Spyder today.. I want to make sure I do it perfectly for obvious reasons. I wonder if anyone could post a picture of their install for me please. I feel like I don't quite have it right. Seems easy but um I have an extra part ?
Oh and make sure the positive/negative terminals are tight, mine were loose this last time I checked....
first off thank you for your reply. It was extraordinarily helpful to have your post and pictures to refer back to during the install. As you can see I've run into a problem. I cannot get the negative terminal connected. Very frustrating
It’s been a while but IIRC you’ll need to losen the bolt holding the cable and twist it to allow it to reach. I’m assuming you also have the battery mounted as far to the drivers side as possible?
