Armor All Wheel Protectant Works
I had got a while back an armor all wheel kit. I finally decided to spray a wheel with the wheel protector spray right before installing to see if it would work.
First pic is a couple hundred miles of driving with the protector on and the second pic is no protector.
I should note that when I did spray it I didn't really do a great job applying it so likely I missed some spots or touched the wheel before it fully dried when installing.
When it warms up here I am going to clean up the wheels and do a better job applying it.
Unprotected wheel below.
I'm glad you posted this. Someone else also mentioned success using this product. I went to the auto parts store looking for this, and discovered there are numerous Armor All wheel protection products.
Which specific product did you get? Can you provide a link?
I've been using it for years to keep the barrels of my cars clean. My only complaint is that the coating leaves a slight film and isn't as glossy as the painted surface, but the paint does stay clean and glossy underneath.
Received 5,388 Likes
Location: On a pygmy pony over by the dental floss bush
I use Outlast as well but when I last went to buy some, no one in DFW area was carrying it in stock. Finally found an Advantage Auto Parts location that had 8 cans not on the shelf. I drove over and after talking to the store manager, found that all their stores had been given a "do not sell, remove from shelf" order. They get these directions from time to time and dispose of whatever item it might be. They GAVE me all 8 cans they had in their stock room. If you can still find it on the shelf or on Amazon, please post back here.
About three years ago one of the local auto stores had the outlast on clearance for $3.50/can, I bought all their remaining stock (6 cans). I still have three left, again only used on barrels.
1) Get all surfaces squeaky clean before application. This is the hardest part of getting the best results out of the product. The cleaner the surface, the better your results will be.
2) Apply per directions on the can.
3) Do NOT touch any coated surfaces with your fingers or rags or anything else, even after the product has dried, but most importantly don't touch before it has dried. Anywhere you touch it you will see more brake dust collect. You will actually see where your fingertips touched the surface as some brake dust will collect there. If you touch it before it has dried, you will get a lot of dust collected there instead of a little bit.
4) The longer you let the product dry, the better it will work. I usually apply the night or day before I plan to drive the car next. I plan for a 12 hour drying time.
I got ceramic pro on my summer and winter wheels. Seem to clean up nice.
Been swearing by this stuff for years. Works fantastic. Has allowed me to dramatically cut down on the car wash frequency.
Key is to follow the instructions. Use it liberally, everywhere, and let the car sit overnight without driving it, so it can dry and not fly off.
They now sell it in much larger cans too.
