Rodent problem
I never have a problem with mice, rats, etc.--the brown snakes keep the population down. (The brown snake is the second most poisonous snake in the world! I'm glad I don't see them often at all.)
Spread cotton *****, each with a few drops of peppermint oil, around the car. They smell nice (much nicer than moth *****) and seem to repel the mice.
Thanks for the suggestions regarding repellents. I'm going to keep setting traps until they go undisturbed for a couple of days.
As of this morning, I've trapped two mice inside the car and none outside (But they are disturbing traps outside the car. They're just so small they don't always trip the trap). From signs outside the car, it appears they are climbing up the right front wheel/suspension, but I just cannot find the actual entry point into the cabin.
As I stated before, I removed a lot of seed and debris from under and around the battery and cabin filter housing, but the cabin filter and filter housing are intact. There are no signs of seed, debris or shredded/gnawed material inside the cabin...Just mice. Anyone have any idea about entry points other than the cabin filter?
I keep lots of decon blocks around the shop and hanger for this reason. Glue traps too, although this year, I have caught 2 baby rattlesnakes in them!!!
I use glue traps and cut up bars of Irish Spring (Original scent only), apparently they hate the smell.
Someone recommended Swifer cleaning pads to be placed in strategic places around the car. I bought some but so far cannot vouch for their effectiveness. They don't have a smell I noticed so I wonder but I'm trying and will report back.
I hear that dryer sheets keep mice away. I am tempted to put some by the cabin filter as I put my car into storage today. And they love to chew on the wires because of the electric shocks they get. It gives them a little buzz. Kind of how we get when we drink alcohol.
I'd try chewing on your car wires first, and if that's not enough of a buzz try the paper clip method. Make sure you are standing in water while you're at and use a non gfci outlet.
FWIW, when I owned both of my Porsches and stored them in my garage for the winter, I would place a number of cups of mothballs all around and under the car. Although the garage smelled like my grandmother's closets, I never had a rodent problem with either car. And there are mice, chipmunks, and voles around (and occasionally in) my home. I'd read that the naphtha in mothballs acts as a repellent - it worked for me.
It could just be the foam AC duct gaskets disintegrating on their own, no rodents involved.......My Cayman would emit black chunks of foam once in a while from AC ducts.
Newer cars have soy and other plant based plastic coatings on wires which become a food source for mice, unfortunately it means we need to be more diligent with our pest management. I make a point to walk around the garage regularly in search of mice droppings and other hints of rodents.
Ask me how I know.
Check your wire harness that runs along the front steel beam at the top of your frunk.
They love to chew on the soy-coated wiring.
Set-up some traps with peanut butter.
You should also try using peppermint powder placed in strategic areas of your garage where they might be able to get in.
The powder acts as a repellent.
