Verus - Carbon Rear Diffuser for 987.1 & 987.2
Paul, very helpful. So to way simplify this... Moving the bias forward, a proper splitter and air damn solve the understeer issue, correct? In regards to the air damn, how does that affect airflow into the three radiators? What considerations should be made with spring rates on the suspension? Thanks
Current car on the track is running MCS 3-ways at a 550lb/800lb split. We are still working with them on the car setup to improve track times. We are probably going to decrease front spring rate a little more and see how the car reacts. We are looking at ride height on all 4 corners using 3 laser ride heights on the chassis along with regular data acquisition.
See attached document. This is our basic aero setup guide.
Paul, this is helpful. Particularly pages 9-11. I understand at a superficial level the relationship between downforce and drag but I'm not sure how to use the info on the charts. I'm glad you are doing the work to provide actual testing data though as my guess is that most aero on the market is just copying others. Could be good or bad, who knows.
Looking again at the diffuser, it looks like covering the exhaust would cause heat build up in the engine or more specifically the trans area. Do you have any operating temp data with and without the diffuser? Also, do you have plans to test on a pdk car, as those run pretty hot, even with coolers, which are located more towards the rear of the trans near the exhaust.
Thanks again, I appreciate this discussion.
We have not had any issues with the temperature of the engine or transmission on the track. We do not have any logs of this, Since we never ran into an issue with it, we never thought of gathering this type of data for our consumers. We have not tested this on a pdk car with temperature. It shouldn't be hard to solve the heat issue though if it arrives with a pdk. I better heat exchanger with a fan should solve it without much issue. We do not believe the diffuser would cause an issue with overheating.
Let me know if you have any further questions.
Sorry that I missed your post. No, we have no issues with heat from the exhaust to date. GearOnePerformance has been tracking their car for over a year now, we have been to a few track days, no issues with heat to date.
We have now created an underbody panel that fits with both 987.1 and 987.2 subframes. The picture below is of a prototype we put on before a track day.
Prototype Flat Underbody Panel bolted to Rear Diffuser
Full Underbody Photo
We were able to capture some pretty awesome rooster tails recently at a wet track day. Our shop car has our full aero kit on it, including the rear wing/spoiler combo.
We are finishing up our Cyber Monday sale; for those interested in some functional aero that will help reduce lap times it is a great time to snag some of our parts . We've had a few customers report back 2-4 MPH faster front straight speeds due to the reduced drag which is pretty awesome to hear/see.
