Window roll
Window roll
Hoping you guys have the answer for this one. Recently picked up an 07 Cayman S for my Dad. When opening the driver's side door, the window will auto roll down a bit just fine. When closing it though it won't roll back up. Same with the full auto roll up, I have to hold the window switch up the whole time it rolls up to the top. Auto down works fine. So I replaced the 3 things, the window switch on the inside, the door latch and the microswitch off the handle. Still have the same problem. I've tried the whole reset process of holding the button all the way up then down for 10 seconds each. Still doesn't resolve it. The only thing I haven't tried is maybe replacing the fuse? Would this be a fuse issue? Help! Anyone else able to resolve this issue?
