That's The Brakes: Pedal to the floorboard
Rennlisters:
I could use a moment of your guidance with respect to a brake pedal going down to the floorboard. Here is what I know:
Thank you for your input and guidance. All is greatly appreciated.
Dan
- Stock 2011 Cayman S (987.2)
- Track event decelerating from 100-ish MPH
- Brakes were warmed up (20 minute mark of aggressive driving)
- Brake pedal went to the floorboard slowly (about 3 seconds)
- Car slowed down but only slowly (like applying half the brake pressure)
- Brake fluid had come out the reservoir (a decent amount)
- Zero air when bleeding the lines
- Good rotors
- One-third remaining on track brake pads
Dan
Did you check and make sure there's no leaks in the lines and thee seals in the calipers are in good shape?
Thanks for the responses. I'll add:
Thanks again.
Dan
- Reasonably new stainless-steel brake lines
- Zero brake line leakage (not a drop anywhere along the lines or at the calipers/pistons)
- New racing brake fluid (600 F+)
Thanks again.
Dan
Sure sounds to me like you boiled the fluid. You want fresh fluid for the track, and make sure it's DOT 4.
(Posted at the same time as you. If it was fresh racing fluid then no idea.)
That was my first thought as well. I mean, I suppose it's possible the brake fluid was still boiled despite being high temp/racing fluid? I know I've had that happen on my Audi RS5, but that's a 4000 pound pig.
I had this same issue. The 987.2 system is over boosted. I replaced the master and booster with th 997 gt3 units and it’s perfect. Still have heat issues but no pedal to the floor.
You lost some fluid right? Did it come out from around the master cylinder or is it unknown where it leaked so far?
Fluid can leak out the back of the master cylinder and into the booster on some cars. Usually there will be seepage around the booster to cylinder interface.
Did you check brake fluid level before the event? How much brake fluid did you lose? That would be my greater concern, a significant loss means that it's going somewhere.
But also keep in mind that when pads get significantly worn down, it takes more fluid to fill the caliper pistons, so the reservoir may read lower than expected.
Thank you each for your responses. All is greatly appreciated. GMAN-3280's feedback is in line with the race track consensus pointing to an issue with the master cylinder. Since we know the brake lines were okay (no leakage, no air, etc.), the displacement of brake fluid in the reservoir must have occurred at the cylinder (via a piston issue?). It's headed to the shop.
Thank you again.
Dan
Thank you again.
Dan
I could be wrong, but I don't see how the MC could fail in a way to cause fluid to be pushed out the reservoir. My thinking is still that the fluid in the lines boiled, which pushed fluid out the MC. You wouldn't find air in the lines when that happened as when things cooled down the fluid in the lines would just re-condense (there's no way for air to get in there unless the MC was completely drained.)
Anyway, see what the shop says.
