Cayman R front lift reduction
Old 09-04-2018, 09:50 AM
GTERACER
8th Gear
GTERACER's Avatar
Default Cayman R front lift reduction
I noticed the steering was a little light at 80 mph so I installed stock 2012 GT3RS 4.0 dive planes on the front of my Cayman R to reduce lift. The steering feels better at speed with the dive planes installed. Because my car already has silver mirrors, side intake grills, and Porsche door livery, the silver dive planes match the rest of the car.
Cayman R with 2012 GT3RS4.0 dive planes installed
Old 09-04-2018, 12:11 PM
SeanPatrick31
SeanPatrick31's Avatar
Nice addition, looks great. Would you kindly post up a part number? Thanks.
Old 09-04-2018, 12:16 PM
GTERACER
8th Gear
GTERACER's Avatar
Default Part Numbers for dive planes
The part numbers for the 2012 GT3RS4.0 dive planes are: 997 505 333 96 M7Z left and 997 505 334 96 M7Z right.
Old 09-04-2018, 12:19 PM
Marine Blue
Marine Blue's Avatar
Very nice! A few questions.
1. Do you notice any change to the rear handling at speed?
2. Have you made any changes to the alignment.
Old 09-04-2018, 12:42 PM
GTERACER
8th Gear
GTERACER's Avatar
Quick answers:
1. Noticed a reduction in high speed understeer, but no issue with the rear of the car at speed. There is still more front lift than rear, so the car is stable.
2. No change in the alignment.
Old 09-04-2018, 01:01 PM
ekam
ekam's Avatar
You could've got a front lip first as these dive planes add drag.
Old 09-04-2018, 01:08 PM
SpyderSenseOC
SpyderSenseOC's Avatar
Received 1,310 Likes on 782 Posts
How do they install? Need to drill holes?
Silver Surfer
Silver Surfer's Avatar
Dumb repetitive question deleted.
Old 09-04-2018, 01:40 PM
yachtfund
yachtfund's Avatar
These look great! Makes me want to do some high speed testing. Interested in how these are installed as well. Are you running stock Cayman R suspension?
Old 09-04-2018, 02:43 PM
GTERACER
8th Gear
GTERACER's Avatar
The dive planes come with double sided thin foam tape (peel and stick on), and I added a single aluminum rivet in the middle of the flange just to make sure that they do not fall off. Not sure that the rivet is required but since the curvature was close to the shape of the fascia, it seemed like a good idea. The R already has a small splitter added, so the dive planes are another way to use an RS factory part to reduce lift. Sport Auto measured the R front lift at 28 kg and rear lift at 9 kg in a fixed ground plane wind tunnel at 200 kph. My estimate is that the dive planes reduce the front lift by 5 kg to 23 kg and increase the rear lift by 1 kg to 10 kg, since they are installed ahead of the front wheels. Overall lift at 200 kph drops from 37 kg to 33 kg and the center of pressure is still behind the CG, but closer to the CG than stock.
Old 09-04-2018, 04:45 PM
PorscheAddict
PorscheAddict's Avatar
They look cool. Did/do you race GTE cars? If so, I won't call BS on feeling a difference in 10-50 pounds of DF on the front end like I would for 99% of drivers
Old 09-04-2018, 05:12 PM
GTERACER
8th Gear
GTERACER's Avatar
Thanks for the positive comments. I have been fortunate to engineer factory backed GT2/GTE/GTLM race cars since 2008. The job consists of: using driver feedback and data to adjust the setup to go faster, analyzing any part failures to identify root cause and propose solutions, and developing the cars between races using test rigs, simulation tools, and my experience. Years ago I worked for an OEM as a development engineer where I got a lot of seat time driving and evaluating cars. To me steering feel is the personality of the car, which is what drew me to the Cayman R since it has great steering feel. The front aero lift at speed reduced the steering effort above 80 mph, so adding the dive planes was a nice way to maintain the car's 'personality' at higher speeds.
Old 09-04-2018, 06:13 PM
PorscheAddict
Right on. Good contribution to the forum. Did you use CFD to come up with the DF estimate?
Old 09-04-2018, 06:55 PM
EYEHAVEYOU
EYEHAVEYOU's Avatar
Even without the reduction in lift, this looks fantastic for those with silver accents.
Quick Reply: Cayman R front lift reduction
