Anyone in the SF Bay Area have a big brake kit?
I'm experiencing huge pedal travel and bake fade on the track, and I'm considering replacing the stock calipers on my 987.2 S. I'd like to see what the pedal feel is like with various BBK options. I'm looking at Brembo 380/345, StopTech 355/332, and Girodiscs, but I'd be happy to compare to anything.
Thanks!
Thanks!
Ah so no difference in pedal travel or firmness at all with the new hardware? Thats the 355mm/332mm you have? Do you have the PCCB or GT3 brake master cylinder?
All of these issues can be resolved with SS brake lines, GT3 M/C, Castrol SRF brake fluid and track pads.
What pads are you running? Just upgrading to something like padgid yellows should help any fade. Otherwise, I’d say try braking less at the track! Seriously, you may be over braking. I tracked for years on stock calipers with track pads, ss lines, gt3 master... all good, no fade... ever. You can also add clip on Cooling ducts. My calipers did turn a nice red-brown
What pads are you running? Just upgrading to something like padgid yellows should help any fade. Otherwise, I’d say try braking less at the track! Seriously, you may be over braking. I tracked for years on stock calipers with track pads, ss lines, gt3 master... all good, no fade... ever. You can also add clip on Cooling ducts. My calipers did turn a nice red-brown ��
Can't speak to the M/C, but the SS lines and SRF made soft pedal a complete non-issue on my SP3 car. And that car was running almost 10% heavier than these at the time, and with smaller brakes. Practice, qualifying, sprint, sprint, qualifying, enduro... rinse, repeat. No soft pedal.
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
As someone who has tracked a Cayman GTS and then Cayman GT4, stock brakes on the 981 cayman s, GTS brakes are not up to par for track duty. I routinely boiled my brakes even with upgraded discs and 6 piston caliper
I did this back in 2015. I had a Cayman GTS and I sourced a set of 996 GT3 6 piston calipers and 350 mm AP racing rotors from Vision motor sports in Socal. I kept the rear brake setup stock which is a mistake as I ended up with a lot of front brake bias. Alas, as I got faster, I Still got fade and would boil my brakes at the end of each track session.
Thus, I sold my GTS and upgraded to a GT4... moral of the story. Get a GT4.... I have never ever had brake issues in the GT4 period.
My advice to you, get a set of GT4 brakes or the AP racing caliper/disc solution from Essex. I am not sure they will fit the Cayman but I'm sure they can fab up the appropriate adaptors.
A week before the track day where they got soft.
So you'd go 350mm even though you still experienced fade with them? I will soon have Apex wheels that will fit 380mm rotors. What sort of lap times were you doing at Laguna Seca when you experienced the fade?
