PDK gear oil change (not clutch fluid)
Has anyone DIY'd the gearbox oil on the PDK in a 981 or 987.2? I had the dealer do the clutch fluid, since it requires PIWIS, but figure the gearbox part should be DIY'able. I'll probably also go with Redline or another non-OEM fluid.
Easy job. We use the Driven Go 75w90 gear lube in all our PDK race cars with years of excellent results. Make sure to use a fluid with the proper GL-5 rating and LSD additive if you have a LSD.
Thanks Charles. Do you know approx volume?
Nevermind, i found it. For future use by others, the PDK fill quantity (gear oil, not clutch) is 2.95 liters.
Man a DIY on this would be fantastic!
I'll try to put one together (which might be worth what you pay )
Went with Driven 75w90 without LS additive since I have an open diff. 4 quarts to be safe. The factory manual shows 2 drain plugs for the trans fluid, one on the diff itself and one on the transaxle. Only 1 fill plug.
Here is a technical guide we've put together for the PDK service:
https://www.dropbox.com/s/9o6hp7wqrb...rvice.pdf?dl=0
That appears to be for the clutch fluid rather than the gear oil (it calls for the Pentosin FFL3 DCT fluid rather than 75 w 90 gear oil). For the gear oil, the service manual I have says to remove the diff drain plug and a drain plug next to the trans pan, and fill them back via a fill plug further back near the diff. Approx. 3 liter capacity, rather than the 5 liter capacity in the clutch reservoir. Does that sound right? I already had the dealer do the clutch fluid change since it requires PIWIS.
