Help! Error codes (U0423, 8023, C112, C150, C152, 8012)
Hello all,
I have ran a diagnostic and was thrown these codes:
U0423 (DTC Count: 1): Instrument Cluster Fault
8023 (DTC Count: 1): Outside air/recirc, air flap motor
C150 (DTC Count: 1): CAN timeout Engine
C112 (DTC Count: 1): Fault, display CAN
C152 (DTC Count: 2): Communication PSM control unit
8012 (DTC Count: 2): Voltage Supply, below lower limit
I believe most of CAN errors could be due to driving once a week to two weeks without a battery maintainer. However, could U0423 and 8023 be also due to battery voltage? I was assuming so since DTC count is only 1 for these items.
Thank you very much for your help.
