991 clutch bleeding?
Old 06-16-2018, 05:41 PM
Pollorey
4th Gear
Pollorey's Avatar
Default 991 clutch bleeding?
The 2013 911 Carrera AKA 991 doe not have a bleed screw on the slave cylinder. It has a plastic line that goes to the reservoir, above the fluid level. I just replaced the hydraulic line at the slave (the line somehow was not attached to a retaining clip and rubbed on a transmission component until it sprung a leak)...how to purge the air out?
Quick Reply: 991 clutch bleeding?
