Audio Upgrade
Audio Upgrade
I’ve got my 2013 Boxster center console apart, the original head unit removed and ready to install the new head unit. My problem is this isn’t a 996/997/987 so I don’t know the wiring. I’m looking for the ACC wire that gets powered when the key is plugged into the ignition. Also, I’m going to need the Ebrake, and if possible the headlight switch wire. Does anyone know what colors and where the connectors are located? I did the search thing for WSMs and wiring diagrams but it appears they aren’t commercially available.
Thank you,
Jeff
2013 981 Silver/Red/Red
Thank you,
Jeff
Registered User
Thank you,
Jeff
Thank you,
Jeff
https://techinfo2.porsche.com/PAGInf...?Type=GVOStart
An hour session can provide a bunch of WSM material!
