Time delay relay
Time delay relay
I’m trying to locate the time delay relay on a 2006 987 Boxster that turns off any battery drain after 30 minutes once the ignition is turned off.
It’s not on the relay board next to the fuse panel. Must be someplace, but where?
Please help!
Page 234 Boxster owner’s manual:
If the engine is not running and the accessories are switched on, the vehicle battery will be discharged. The power supply is interrupted after 30 minutes to protect the vehicle battery. If the load is to be switched on again, the ignition must be switched on once.
Please help!
