Procedure for starting hibernated cars?
How many Honda's are stored each winter? Letting a car sit and run once a month is a bad idea especially in an unheated garage. Better off letting it sit for several months and putting a battery tender on it.
I'm sure the number is actually far closer to the number of Porsche's than you might think. Plenty of people have their modified cars, or just a rare or coveted model which they park for the winter. Honda sells more Civics than Porsche sells vehicles.
No doubt they do sell more cars but I have never encountered a Honda owner who stores their car for the winter or cares if they need to spend a few grand for a rebuild. A couple of Acura NSX's and they seem more **** about this stuff than most 911 owners. I for one am not so worried about the boxster which is a warm weather DD but my older Porsche's are climbing in value exponentially and original engine in good running condition is a must for value. I would hate to do damage and have it end up costing me 10's of thousands in rebuild cost not to mention depreciation. It would appear the direct injected wet sump engines aren't a concern but never hurts to take care of what you own.
There are people out there daily driving a Cayenne, Macan, Panamera, or even a 911 in the cold temps and winter weather. There is zero chance that Porsche designs their motors such that cold start and drive off are going to grenade them. Half the cars they sell wouldn't last a year. Couple this with advancements in fluid technologies (oils and such) and new engines are much, much more robust and durable than anything prior. Sure some engine designs get things wrong (Porsche IMS bearings, Ford with the Focus RS heads / gaskets, GM with cooling issues on the C7 Z06). But as a whole the technology improvements relieve us of most things we used to worry about. Manufacturers also do a lot more work to test and validate the products for such things. My employer shares a winter vehicle testing facility with Ford. I watch them pull vehicles out of a drive-in cooler (climate controlled quonset hut that'll go to -40 degrees) and immediately launch them at WOT and run them up to redline to test the engine and driveline components.
^^^ My concern was based on possible lack of lubrication from sitting. I have seen a lot of 987 engines detonate from lack of lube but that is usually on track. I am not worried about temps or other conditions. I looked into this further and unlike the air cooled cars or any of the newer metzger engined cars which can build oil pressure by cranking them without supplying fuel to help pre lube them, pulling the fuel pump fuse on these won't build enough oil pressure to do anything. So start, warm and drive is the best procedure.
It is hard to break a 40 year old habit and after owning the others for a long time I just wanted to make sure the 981GTS stays around with them as I don't plan to buy another unless they revert back to N/A vs 4 banger turbo.
