Favor Needed: Pic of hose routing for trans cooler
Im working on transmission cooling for my spec cayman manual... I plan to use the oil/water intercooler used on GT3/Cup. Surprisingly its the same (very similar) inter-cooler used on the tip and PDK in the Cayman.
Before I go fabricating a bunch of hoses to get water back to the intercooler, Id like to see how the factory did it and leverage as many OEM fitting and hose as possible. Unfortunately PET splits the diagrams at the hoses and does not give a clear picture of how its done.
If someone out there with the Tip or PDK would be kind enough to get under the car and take a pick. I would be forever in your debt..
What I'm most interested in: Where did the factory source and return the water from the engine? I assume there is a special hose or fitting at the bottom of the water pump with a Tee.
Thanks in advance,
Jeff
Thanks in advance,
Jeff
