Driver door window won't close completely 2007 987
Hey, hi y'all.... 2007 - 987 Boxster - 5spd Manual
I need some help ... My drivers door window won't go up all the way. Using the auto-up mode or hold the toggle switch up. With the window not going up all the way, door open or closed; convertible top up or down.... The interior lights stay on for over 20 minutes or more AND I can't lock the doors or set the alarm.... Then when I open the driver's door, the interior lights Do Not Come On..... but do come when i open the passenger door.... I have disconnected the battery several times and tried the "Re-learn" process (put window down and hold the button for 10 seconds... then go up and hold the button for another 10 seconds..).. The car thinks the door is open or something is not closed fully... I have changed out all 3 micro switches inside the door, one at a time, AND it still does the same thing..? Is there any way to isolate these symptom separately? Could the ignition switch be faulty?? .... Uggg. Any ideas???? THX RMac7 |
Was there a cure?
