Best oil viscosity?
Best oil viscosity?
I've spent a lot of time looking and -- amazingly -- have found very little recommendation about best viscosity for '18 718 in hot climates (TX). I know what the manual says, but..
So, anyone have any good thinking about this?
0w40 or 5w50 Mobil 1 are both fine if it is the same as 981. No real need to change oil due to hot climate though. The oil coolers can keep the temps at an acceptable level even in 90+ degree heat unless you're tracking it maybe.
I''m in South Australia (we get 45°C+ in the summer (113°F)) and my dealer's recommendation was the same as PorscheAddict's.
Even on the hottest days so far, in Sport mode the oil temp never exceeds the boiling point of water!
Are you running a separate gauge to measure temp or does the 718 give yo a more accurate reading on oil temp? Sadly the 987 doesn’t include any type of oil temp measurement and all I can rely on are the Blackstone viscosity readings after an oil change to see if my engine has been running hot and degrading the oil.
To get back on topic, I would follow whatever is noted inside the owner manual as far as viscosity. In general if you want to provide better protection for your car you can look into a boutique oil like Motul or Joe Gibbs/Driven.
Are you concerned about oil temperature in the hot weather or having an oil that provides the best lubricating properties in high temperatures? Also, what are the temperature ranges in your part of Texas?
TX summers can be over 100 deg. F frequently.
The manual specifies 0W-40, 5W-40, and 5W-50. The 0W-40 is "for all temperature ranges," while the other two are for temps above -13 deg. F. We never have temps that cold, so all three grades are approved. Question is which one is best.
So funny story, I just had a shop do my oil (first time shop, last time visit) and they didn't wait for the old oil to drain completely out. And then put in the full suggested amount in for the new oil.
Only thing, it overfilled my engine, after the notice popped up, I turned around - the idea was to empty out a few quarts only, but it was super hot and burned the 'expert's' hand trying to stop the rest of the oil coming out.
Long story short, the Motul they ordered for me would take two weeks - they offered some oil called Liqui-Moly - which they say is just as good. Curious to any 9-nerd who knows otherwise about Motul vs. Liqui-Moly.
I redline daily and I am a daily driver so this isn't just a "I wonder" question - seeking best advise.
Muchas gracias!
Muchas gracias!
I run 5W-40 year 'round here in Chicago. Air temps this year dipped to around -10 F, highs in the usual 90's... street car with plenty of "brisk" driving, but no track use (I have the SP3 car for that).
I do run the low-temp thermostat from LN Engineering (opens sooner, more even cooling across cylinder heads, etc.), but the net effect is a warm engine temp that never seems to change, which is reassuring.
I do miss having an oil pressure gauge in the previous P-cars, I also have an oil temp gauge in the 968. In that car, oil / water temps behave pretty linearly, especially when they get real warm.
As long as engine temps are controlled, I don't think you can go wrong with a Porsche-approved synthetic oil in 5W-40.
Just my 2 cents.
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Just my 2 cents.
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Received 5,388 Likes
Mobil 5W50 is on sale now at Napa Auto Parts plus you can take the $12 Mobil rebate, so that makes it $3.99/quart. Great oil. I use this for my March-October driving season. Blackstone UOAs are excellent. Porsche A40 approved (the only 5W50 that is).
