This car sat... what services would you do first...
Old 02-08-2018, 11:20 AM
sweinland
sweinland's Avatar
Question This car sat... what services would you do first...
Hi Everybody,
I'm the proud owner of a new to me 2011 987.2 Boxster. The car was purchased from an auto superstore with 1900 Miles on it on New Years Eve. 1900 miles in almost seven years means that this car sat a lot and I was lucky to find a trickle charger already installed in it. I took the car to the dealer first thing and had them change the oil and also perform a post-purchase inspection. The only two issues that came up were that 1) the "major service" had not been performed. With 1900 miles it was only missed due to time and not mileage. And 2) It could use an alignment.
My question to the group is which other fluids/services would you perform to 'catch up' and avoid issues in a car that isn't presenting with problems. I'm planning on changing out the air filters and the serpentine belt on my own (I feel like I've got at least that level of mechanical competence). I plan on taking it to the dealer for an alignment (so that I don't run the tires down unevenly). What are your thoughts on brake fluid that sat for 7 years or transmission/differential fluid service? I've read that those fluids are good for 12 years or 50k miles.
The car is a daily driver so isn't being track raced or anything. It's warrantied by the place I purchased it for 50k miles or 5 years. It does look like it sat outside in Pennsylvania probably with a car cover on it. (Wheel crests were faded and lug nuts were rusted - both have been changed out). I've almost doubled the mileage in the month I've had it and I love it.
Thanks for any input.
Stephan
Old 02-08-2018, 11:23 AM
bminingham
bminingham's Avatar
what about tires? 7 year old tires that have sat idle most likely need to be replaced regardless of mileage.
Mrg02D
Mrg02D's Avatar
The brake fluid is the only thing that comes to mind. That definitely needs to be replaced.
Old 02-08-2018, 11:32 AM
daylorb
daylorb's Avatar
Tires for certain. I'd imagine there is quite a bit of settling of every fluid, they are inexpensive to change - why wait?
Old 02-08-2018, 11:34 AM
996AE
996AE's Avatar
Received 1,449 Likes on 956 Posts
Ask why alignment?
With 1900 miles in less something was hit like a curb or something....
Oil beens done so brake fluid too.
Old 02-08-2018, 12:04 PM
LexVan
LexVan's Avatar
Received 5,387 Likes on 2,509 Posts
Just ZERO out the maintenance. Oil is done, and you plan to do the engine and cabin filters and serpentine belt (smart!). So do the:
Brake fluid
Manual gear lube 75W90
Plugs
Coolant flush
Replace water pump (optional, but you should consider)
For the next oil change, run a tank of fuel treated with Chevron Fuel System Cleaner With Techron
New battery?
Clean out all cabriolet top drain holes, and AC drain
Old 02-08-2018, 01:38 PM
Marine Blue
Marine Blue's Avatar
Based upon time and miles I would do the following
- tires
- coolant
- gear lube
- spark plugs
- brake fluid
I would check the air filter but likely it’s perfectly clean and shouldn’t need a change, same with the cabin filter. I would also check the belts but they may be fine considering they haven’t been exposed to heat.
Most important recommendation, DRIVE IT!
Old 02-08-2018, 01:40 PM
Zeus993
Zeus993's Avatar
Received 1,239 Likes on 570 Posts
Wow. What a find.
I find it odd that the dealership did not recommend tires to be changed before the car left the service bay. Tires have a shelf life of what 3 - 5 years (someone please step in and add the correct data) from manufacture date.
You can find the manufacture date on the side wall - 2 digits for the week and 2 digits for the year. [img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBgkIBwgKCgkLDRYPDQwMDRsUFRAWIB0iIiAdHx8kKDQsJCYxJx8fLT0tMTU3 Ojo6Iys/RD84QzQ5OjcBCgoKDQwNGg8PGjclHyU3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3 Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//AABEIAKABGgMBIgACEQEDEQH/xAAcAAACAwEBAQEAAAAAAAAAAAAABAIDBQEGBwj/xABFEAACAQMCBAMFBAcHAgUFAAABAgMABBESIQUxQVETImEGMnGBkRRCUqEHFSNiscHRM0Ny kuHw8YKyJFNVY5MXJTVEc//EABoBAQEBAQEBAQAAAAAAAAAAAAABAgQDBgX/xAAkEQEBAAICAgEDBQAAAAAAAAAAAQIRAyEEMRIFIoFBQlFSYf/aAAwDAQACEQMRAD8A8dPceK/+HlSN7AtzAU0K0nvRljgZpuz4sl3wuSNl1RIQ6ysuCh6jPWiC2kmkZmTyggeG3lB3Awx6Akg empTyr0qCwhaQK7lRJp3KL5Ih+6OpwGGf3SBWisMaxssaZzsQW94nbntz5cvwGuQIuNKa9JA 0DHmOTnOPxHSTjG0kcg+9XSyqjBwunGCM+VvTPryz0BU9KyKg6iTxCSW2JfGCSTq1Y6E48QD owmXrU2jDeXSuobGMHYjlpz23wDvsUPSk3v4FbLyuQSTlEyck7tzxnIVuwYvgkNWlaxRzW32 m2lEyR4V10keHnkHXopyVz6jtUVkNG/6zmvoXkYBPBeTOBkgltuhIOSO+qi7ufstusy6iFkBcR7HTnfBqi0eew9oJba4d5bPie51HBz vpf/ErAj5EUSyPho8jWDpA6E8q1+iNaH7GLaGXh80jwOviAgHxV31HPPfKeIvQvGw317+e4ksnCr 9ruCNfslyMusAwitzOnspyGUfhYdq1EUQQxqPEwP8Ay/e9CBjnlcgdHTH3qskkDjR5GXmMe6eufgdWR+62Pu1kZY44k0EUZljkCHEKyQLI6ZOcKSpI36 cqtsQZiHfIjfBAc+9kZy3puNuxz0oFlDFqaGEI+coR72d9h+95dv3lA60xHkrgMMEg5X3e+3 phsj918dKbVJooUGqOJgzHzlPfBHUHuMZHqhHWolFDDJjxybSo0HsP8Pm2/ckA+7U53KKWZWGfKdPvZ6Eeu237y+tJPPo88hA6aV3GN/y3P/SwHSgskkQEqrOCp8pxkjf+IwD8VPelQI5Jj+0EaaxkcwNuQ74GoDOxGO1TiuYgrGZTK6AkRY yAP58qp4rxtb2wsxNBGjQyExSRqFPhld1IHPBAx8+9A5JHJccOvfsMEa+CvieM8uJXwfMBvv 8AAUhYcQeYan5JDoUfdT/e+1VSXhmka6KLbBlClUGNeBjOPWqFUSKAf2cfIRjqO5qhp5mkGmLZfvSdT6CoO6xroRQAPyq IPkz2qot5lHUnA9TQTMu1VvLpBOTTp4fMgBvZUs1PITe+fgg3+uKSmmsra5jaHVcqoOsXAAV zjbAHQc8E9KCNpBPduWigklbPuoM6adfhywf/AJG7gg2/swfEf/KvKqBxDifE2FrZJKwxtDaoQB8l6fGu/qZoB/8AdOIW1n/7St4sn+VdvqaCL3fDbf8AsbaS4b8dy5Vf8i7/AJ1X+tL+5PgWoaNT/dWcYjB+IQZPzJqxpuDWhK21rJdsDtJcvgfEKv8AA1XLx27KeHC4t05aYFCAfTf86mxI8Gv8B 7xorVTuGuJAp+XWux2vB4cm5vbi5bPu28ekH4s+PyzWXLNJI5Zz5zzPU/Gq8sxHM1BsHiNhBtacKts8w1zI0xH/AGr9Qark47fvD4KXMkUWMaIcQp/lQAGlVsLnIVoWjzkgyjQDjGefPGRUbeFXn8KdzGMHzAZ/mKCl3YnOedQJPWtGJLTBXS7ssTk63AGQMjHLtyql5kVojGkasqj3RzPc+tApgnoe9S0kEZ60 zrV2UDxGLZDrsB6VRIrlsEE4GM4oOvCUzkocetR8MfiFdCS42Q4+FS8Gf8DUHv7K2BkEtyx1 A7Rg50dPrkMPQrpPOnZhpYKNPl2wdkIO2k+h1aTywrg/dqUcU0josalnKgFC41nG2+Tu3lCnHNkDD3qw5eItLJNGD4bQuUYYKn6HlzP5itIdMsEcq+Ld GMA4zKfMucZZsA4Y+UsTtrRiNnNLcdE0V5BasVQNF4ihGBUjuCOm5wRjY46UjeWs0FzHIs8E 1rLGHj0jDaSORHRgQQQe3ar72zv5uE293BD4iWWpsRuGYRk75UHIA70FN3wW5ltILmzuWy6H QijA1hiNJ9Tg/AhR94VL2c4gY5YrpgrRnMc8R92SM7OCPUfnimOGcahS0lhxFPBOdbxO2ko+AMg9DsM/4R2pWOWOe7kWBUBdy7ad1XuT37/Wgc4nheN8OiR9apctpMnvHpqz1J0gNufMhO2veBXXeSJlVCsWcnl8/Sq+KTrBd8OknYCP7RrYkajkDTnP4tgG9FQ/eq+00u802tWDSMwfGxXJwcdsb/Wg7NqLR6hJkHDANgnO3P8AGcAZ3w6IfvUQkuivq33I8unIO527HJYDbAZh0ouBqyCuDnBXXj IOF59zsueh8Nq5FgDWWAOdWojBOd+XfO57HUKglMmRsjgHYaW82ewP4jgYOTh0Q9apMiLEWk 8NUzkFM6Adz5R2OosAOQdl6CryjyjykQRHP7aTIXlvg98Y5b7A0wI+G8N4laNdiLiVlcocTb gKwPmUr3BKn1B+NNKz9JnIlkdbdD/eNux+A+Q39OlXW8sXC+Ki0aSzubKSMMLkR6w8bDBznJUqQQcYII+FYMsts8EyTzzCZX/ZBTtzOQflil53fUGZ/DiKaMDmdycfnQOXEycOvRLwy4a4aQHUWjA0HkRhtQK470mW1Ph1E0530jYL/QVxVeRQoUwxfDzNTtnZSyqRbxgRr78jHSq/FjQKiEf2kza3yeWyqPSr+Hi8uPHit0aVZCp0aT5SORz0OCR8CfQiN09pbSxL4y3TK2ZVAIjx 2B5mum64pxki2sopDb5C+HChWNQeWrG3Q7t2NUWTLZ2p/wDFXIlcDeK1Ib5FzsPkGNL/AK3l1CLhkAti3lHgZMrehkOXPwGB6VcOF8PtV1cVv/ElGc21pglT6ty+ldk9oRbI0XCLeKxQ488Y1SNjrqPL5VBFeA3vh/aOJTw8OgbOGuGOtvgo8x+lc18DsQwggl4hLth7pjFGD6RqdTfNh8Kyp55rmQyOxZ295mOWPx J3NStbGe7lEcCvJKfuoMmgbveOXtxEYBL4dtnPgW6CGL/ImAfid/Ws1mdthn6U3bwQeJouJDFyOyZJ3/KrmmtYl0xwJrKkF5CW77gdOeflQJW9lcXOTFE7AcyBtTlvwvVIgubqKMMDjzatx0OOXxqq5v pZtSlmwR7u4AOotnFUxCaY6YlLY6KKBtrSxiD+Jf8AiSBQVW2j1AHfZmOBjluM86qt7+e2jl S2mkjDkM3hnGcct+9Wy2F3aRK81qUibfVnI+o2Hzped/2JVNkz250DBS5S40zoQ8b6syEsc7evI1RHayZzrI6Y64rUWMNZ2pQAK8QbSO42P5iuBOVXSb JRcNVhl3J9AKHtINQjjG43ds8h2p7G+Og2z2qP2dFChds8z3poUGKFNo0wajt2FNKhL7Y5VI W+dsebrVCwTycq7oPanBatpOx257UfZfjQN3gvbe5jE8Qa3nhEsFzGxIdTnG/PO2CNiCKOOXckws+LaC8qZgu3H3z90n1x9cUxwuyXik62guvBkkGYCd1Zvw+mroe9aS2dubV 7EwsoKlChHmJzuD+9kHH7wx96lGPZ2cfE2a2im8G5mH/hJdXkL4zoP7rcs9DjpnKFlxG9tLw6YbqLiEDHHhAhgVznl8Dt6Uxw/hcy6opbsCBGyjqu7rzBB6Kc6u+M9jW8gVpWfSxlyNWMaieh+O2x7gd6gzrixhvbgXN9aWyXL jEghHhxHGPMwUgBtxq04BWRHA2bLUUaRRiOEGKNRsAm49cd9uWOYYdau8pjZ8404wwHlOc45 9ACSN/dLpzUUr4wkkEUIZm5kKdx66v5+gNQQurSG5URSooXWGIZsIMYw2R0GQCesbo3NDVupLVQi+T TsNQw3xI/FtvtzU9GqMzxWyu9xcxRNoZwsXnL4B8ueQ95sfEioLxCQyhrKOOLS4y7J4jnlzztV6EjGCPF meOKIZCmb73lIIVdy2xxjB2xtsKra+sY7h4pI3uwf/2GZ1KkrnIU4IIPfnj1pC9kgtuKXI4gBIQTqVX0E9RgjkN+QpSWcmRZo7eKzjXclds9QcHr69 abDE99LPaE3F27iNkZWZtuqnA6bHp2pGWV2ZHWQImgFmPU9x22x23qmMs+o28ZlOrJkkHlX/eabi4c00o8TVNJ+FRsKKUXMsrNaxF3Y5Msh2pqz4bJPIWAaV1GWc+VEHqTsKbnazsF/bkTSgf2cbYUehP8hVC/rPjcngxRlIIpArBV0pCeWSvy5neoJyzWFkcti8lHLcrED/3P+QpV5uI8ZmijXyoz+GmQEjQ4zy5LtWh9k4VwtNV468QudJV1DfslOdm1cz8BWdxPi9xxSU ZVCiZCAIFRAQM4HfYbnJ2FUMJacJ4epe8kbicxXBSNjHCjdzJzb4KPnS17xq7ukaCLRDAx/sLeMRoT0JA3Y7cyaSMBc6ppCSf403DbJ4WuSVECuqlM+ZskAnH/AFZye1QIiOSTIZsKOg/pTUPD2EZkZVSMDOuUhdvQHc8jsAeRpm70WV5GbZ2eNhnLKNQBHIjvzqtvEuoyJWck7ZZsk7g/L/U0EzHBbMRgXG66WcMqeoKEAnr16VXLfyvCqKTF4UjMixghACOeCfTt86shtgGZh2yS25FcJE cLzRxjI3Bc8/lTQRlWa6uJJQmGkYkhRgAk8h6CueBGv9rMB+7Gus/0/OnyEu4Y2M7uxm0MB5V75wPmK0HeSW3ewbiNtBISDHbLABy5DWORNAgto0SwleHgLLustw+vk SD5RgD3Tsc/nT9jaWXFYXEd3djwSNcZCojDuuBt8MVlJcCTh2mRiZoJGKkno+Ac/AjPzNakcdtbLDHdXUKR7YiiBkdvUgdfrVlgqnMXDpcWHiCUjAOskY68+nT50vxG1gaNjaHEJ QSIvUbbr35551bDaTXE5UNmSTntnA7Y6VsHhunACeVQFxV1tCfBLY3fAo3UAGKSSL+DD/uP0qT2zaUGwIGOVafsZAiTcY4ZI4HhmO5iB9Mqf+8UxKbCzZ/tl/BCT0Damx8BTfSMj7C7ISuSM77VY3D3OnQBvy75q+59qeCQhViW6uSnukAKD25/Cs+b24IBW14Xbpj3GkYuRU2p1eFyMuFQjvtzp224HKEDsmAe+K8nce1nF5ztOkP/APKMCs+fit/cE+NezvnnmQ4+lNj309vFChFxJFF2LuBmqNXC/wD1Gy/+Zf6188yM0Z9KfI09XZ8MvYnEYuFFrE4aObB1ODuMDmOR2zsQw5jFb9yxmUy+Zvxs7ka/QseWcAaunlboayRcTS7PLJ5tydR+dWWl5w+5heKa0AkaMmG4STJDjfdccjj5UFrXVqjamuNT HdjGmSRnYj7oyfNjOzax7rA11Lh7qUR2sCZxpzJIAMdug+vp2zWTK3mAG2DzNLXszRmNo2jK jOQx60GzfWt9bzPBfrKJVOWjYcicnPbrn51mXsc3hq9tMqacllJ3rj8aHgRw+K8hjQIqoM4A 6D0GTSz3FzcLiG3bT3kP8qCS3CXllPGQXkaJWU49xwwOfpqHzqmS6cbSSiIEDMceWY/PpUhaO+PtMzFesaDSPypmC3iQgRxKKmgiolllLwwLHnnJKcn/AH8KZhsUH7WeTxjnqdq0Y4Hk1MCFRBlnY6VUd80vdcQjsiVsRqkHO4Ye7n8I6D1NXWlMNEkE eu7ZokxkRgedh3A6D1P50q9/cXeYeHxEQlgjOFOkE8tTcz88CpwcKdz9r41MYYBJ54yx1ygj3lPU1yTi5gVbfhcfglY1iaRc CSRR+Nhy+XbmaglHZW3DnJ4xouZSjo9qDkL2bWPd6HbJ6daWvONXV8DFAoWPSqlVyFIUBRk8 2IAAye1KtEzgtMQcHOkDyj5U5BallieZo4YXzhjzbocAb/8ABpAkIdTapmLsPkB8qYhjiFyIbg+Fj7pj1HbmMZHrTszQWyFYwUmK++uHYHGDnOwBBpG5Z+ IXXiRRkS594MefXJ+NVDdve21uWhMXkZSj+GwL/wCY8uv5bGsoQSTSy/ZlkYMPNgZyMgnPzA3rVg4QiWz3V24aJDsFOFz/ABNPyToLB24aoMiRJdxADyugwHGn8Skeud+24ZEXCpyA819HAWGVGl2z9AfyzVs3DrqyVXuD G8bjKSwvqDDvkfP12Na8jpxHhb3MBOhZTIgJz4YfmvyPL0xSQcrZywjJQFWVW78j9QB/lFWSBN5I4LZ2kbljKdWGapulSa0Zo1YLgsB27U0lqkgRXj1KrZxnY4rXg4bDIPBljJiOTGq5 yo7Z7ds+tO6PG2siqkqs2nbUh/eHKtWON+IQG5s+EzCdd2mR2dWbPMA9fn05V6iD2V4XbW5e7eNFIyWmOCD/AEqN77ScG4ZEkVrG12UGE0jSnyPL8qmpPY8vbey/GJm0i3Eakbs7jB9Nq2oPY2GyBuONXvhRKQRpIjGfUnf6A1nX3tvxa4Zvs7JaqRgeGMsB/iNUeytnH7S+0lrw7il5MpusxpcM2oo+MrnPMZGPnTcG83HeB8IWSC0XxgP/ACEHmPq7Ek/EVj3PthcttaW8UI6M3nb86n7YewvHfZSY/rC0L22TpuogWjYev4fnXlyMVPkpybil5NPLNJO5kmTRIQcalyDjb1A+lKE755/Go0VAUUV2g5RXa5QFFFdoPSpwe4VdUPEHHoV/1qFtwF1zI96EfkwjX67mtkDTgA79R2o0scrzxuc9K0m2WeBwAZa6uG+eKP1bYxZKxaj++c01 NcYyinlzpZpCTQACRoBGirjsKryd+VT3PSrobV5ZQqKSTVkFKjygttnqRtTSQxwDXduEPNYt YUkd2JxpHx37VB7hLWQR2Y+03WDpZV1f5B1xg7/T0Lfh3kS+4lOGiOJI8/tFlB5qw5lvWlFBN3xOYwwRYii0v4SEKzITjUgOzfH51cklnwZAYSs90NSeLpOl1PIFc+Y/l8ahd8Q8e1W0sQyWyEjwyxKhefmbqNz5RtSUQQzELmWc7Bm3PyFZtUXMtxds0t0XRfj5sfyH oKgoSMNoTRjc07aQwu7eOcsP7hX0s2DgjUeR7euO9cuLqGeye0kgjYBy0TounTnmAOeDz3Ox qQSaKO3hYhg5cCSCZAeY3K6cg52xyP0pa6upLlnBXPiSmTA3bWc6t+meoHY1GC2IQyP5EVcZ Y5OO3w9K0pZLfgt4I7mESr4YOxPmUkYIYDfr2G1a0hGOyGczPqOxKA4HzPWm4+JWtjeKgti8 YVVdSDgMW5DsdOTmnb20ML60y0DDVH6g1mX0LPbMgjLnGrSNtWOX8aB+4ju+D3s9tPw9uIWs z+LC5ySyYycY9PltS0Un6pvXto5PFijkS5tV5rPG+xT5hgf+k96uAk4jY2ttapLbrA/ixkSHKE8wD2zuO1aNvwaNCZrtlZsbs2469Dz+dBjWSyWd3eJw4s1jNsqvzx037/Wn4rJ2AZhsMnGNzTV5x7hnDQURhNKuwVenz6V5jiXtPeXWVtwLWI9I+Z+dN6HoJJ7GwixezK j51aRux+VZ157YSDKcPt1TbAml3b/SvKs5ZixOSeZPWuA78qlqt3gnDuK+2HHbfh8Mkk9zcN5mY5CL1Y+gr3P6bvZi29nLP2ehsUC wRQNAWxu7ZyWPrXn/ANHHtPxPhfErfhfBILSKa/nRJrpo9UujPugnYAD051s/pG9vIfaWy4jwW/tyLiyvSbK5TcOoJUqw6H1FQfL6Z4ddPYX9teRDMlvKkq/FSCP4UuQBR0oP0p7W+3Ul1d8Q9n/Zg20vFrWBZtE8fiJc7EyRIOWtRpbrnzDpX5z4hcteXUly6RI0raisSBFz6Acq7aX1za30d7b zOlzFIJElDeYMDnOa9R7U2dvx7ho9q+FRLGzsF4naoP7GU/3gH4W5/Gg8bRUiuKAB3oOUV3bG1MwWF3cY8C1nkzy0Rk1Lde16K0Vv23sfx+4xo4bKoP3nwAK0oP0c8 dkb9p9miHrJn8q88ufix95RPli8dRXvo/0X35/tOIW6/BSaZ/8Apcf/AFMf/Ga875fDP3MfPEoSCG3371RcXAii1FsPINlAzgd8/wAqou5/Ct/KczPhQvrSZVY1SJcHbJz+Z+tdfya0lJID7o3NCKSRmuImN6cZEt08W4IC4ysYPmb1z0HrVHb WDWpkkkEUSnSXPU45DufSoyyzXRW1sgkMUraVllyEkfopYDBb05VGOCbicpaYvFbRsY3WIAN CCCQ2lseTueZx1qU/EPskT23DlWNpMCWSEFFdl2yq8l+PM02JN9l4MPEAZ70MsqrIRrgcZBBdeYP4R8+1I3Uk1yzT XsjAE7RA7gHptyHoKqChW16izZ2OeWeePyyanaJFNetBNI0bAHCqBkkfE8vhvWRXA8c93HAf DijY7u7YRQO/rWlD9n4bJ+xGLhH8zSA69tmRlPujOflg77is/jK2dxNF9lREIjxN4YOAwPbrkY33+tX2lvcTKZMu5ABJOWOAMZJPTYCnsTliSRzKkaqSxwB0y cketO2PClaJpVlhklXURF4g1uAd8L6VGQYt/KPPGwYgY3HPHx5j40hwm6azv44p5SbeSXxIp8Z0MfvfPkw/pWvSSm42XjXCLq3SMRX1qpJjGxkTPPHcdflUbO6tOI8HSxncPNHDmNS+kjHNMnnnAYb9SKjL byWPH47iF2M8T6tcW4J/oeRHY1fDw9JJTLIqIwz5UG+Dzyen+9+dFFld+Jw1bKG3eMhg2l3yY267nkDzwd60LGwXX4l4 dl3A5AfLrVEl5acOhDOFQDZQOZrzvFePTXgMcWYo8777mm5B6W+47w/h2Vt8M/Ly7mvLcS47dXvlz4acsKTk/OsosT/rXKzbtXcmjNcoqArorldHOg9d+jNFi49NxKRSYuG2U10zYzgqpxXlJJHd2eQlmY6mJ6k16rg BFj7Ce0V9kq908NjGe+TrbH/SpryqqWOlcsxOwAyaCGc0AV6HhPsXxviYV47QxRH+8m8o+nOvYcL/AEZWkYDcTvHmbqkXlH1O9eHJ5XFx+6zc5HzADFew9hrfjtlf+NBwqeewnXw7uGQaEmiPPdsb 9jX0zhvAeE8LA+w2EEZHJyup/wDMd60snOSSfjXDyfU/6R53m/h89vv0VPHxBnj4gq8PlOu2ITU7Ieh6Ajl8q0rP9HPBIAPH8e5Yb+d8D8sV7yylSSJrK5IEMh ykh/u36H4HrSs8T28rRSDS6nBXt/pXLyeZzZTcvTGXJlWVZ8A4RZb23DrdG/FoGa0VRVxpUKB0UYrtFcmXJnlfuu2LbXc7561yiisVkUY9aKKD4qhMs7TLyViser8zXVQM/YnfHer4oQW0gav6Uw4MJRIFZ7qTaNV97PZfX16V9frt3FZ5IuGx6psPOP7s8k+Pr+79aZh4f l3uOKFTyYq4EkcqMNirKdnHbpXLOAQBL2aYLL7yPCxV4mGzxMjAgjnlvTn0pe5meXCoqRwqT oSMaVH+Ht6nn2xVRHiXFWkjW3QOVRRHl21MQM++epx06VnrLEWASUec9TTRt3nwqoNhknooH 8KbVoOD6ntZ3NyIyksWGAkB5FdsaehDCsiUVtBY6mvSAwXJLAjQwYYwOThht9RtsazOL3zcU lhaaGPxEj0a1G7jpqxzI3paS9eZyVQIuSoReQG235Cn7VYo2geaHVqb+zZtjjv1q+wvbxCFW nuPJECFUMOZP9Ofyr0PCLyE3v2a2vRbAeTxcaskj73cd+1XiWw4xcjg/FbC3sp9YEU1vG0YVj7viJqIZSdtQORmvPXfDZrW5E1kmiQHDx9B3H9RV110NW5s57G5eKddE qEqyndTn+OdiKXext7gaSXAyCU5gGrnmuLiONbhwxRRHnHIdh3+dLXd9DYKTJ55fuxg5+val sSRpwJbWKM7EbLzG23+8/SsDiXHy7OLZOZ3cjGayr7iFxeuWlbboo5ClCTWdqsmmklkLuxJPeqyc0VyoooortByiugVpc K4HxDi0vh2Fq8g6vyVfnyqWyTdNs0c6b4fw284lP4NjbSzv1CDOPieQ+dfR+B/o2tINMvGZTcPz8GNiqD4nmfyr21ta29lAIbSBIYlGyRjSPyrg5fqOGN1h3XllyyPMW3sPI3s dwnhvE7gQg3M15PHFgsScIgz2wG+tbXCvZ3hPClH2KzjDD+8Yam+pr0PFSUulhzvBEkZx1IA JP1JpKvzfI8rlzutvLLO0fM0YHaiiuR5iiiigCMjFaIP6xt9Jx9rgGV/9xO3xFJ28LTyFEI1BSwXO7YGcD1xk/KpvbXEALKGJVQzNGCTHkZwflXphLq9dNQvRVv2abUgEEn7T3Mj3vhVbKyMVdSrDmD0rFlntH KKKKiCiiig+RRsIgcHB5FjyXpuegzzNXiGOFC96A5K+ZGIK5XkyMNwvOuQeHYp4kcoldlJWa J3QTRnI0SRt7uD2/Ol2y7B5CQBjSnbt/xX17tduHkuZTLOTgjkfjn5Dfl9aikDzuVToObbAeme9UTThTvvSuqSWXXlkK7HB2qh155bZW t5IpYbuCXmPdYb8x35f7JpfQ87ASMz7bnPID+VW+GzEM7ljk7mumLKsgBKsMEg4pA5a/q+xgNxJw9L9AquxJOiNTtk46bgZ6fOp+0HD4Lyxg4twLMZjfRJbMclCRtg9VNZHDrq44JeoM k27E4OnUN9iCOo33WtO1kEUbqqeHEzeWLJ2x8eQ3671Z/qKYry/uBD9qhMYtT5HYglR2zzI5bGrjI0hJY88ksf4moXVwkSGS4YBB9TWBxDik1yxVRohPJQefxqW 6XRziHF/CzFaYJGxk/pWG7uzFmYknmSedRzXKyooortQcoruKsSJpCFRCSTgbE5NBVTvDuG3fFLkW3D7d5pT0UcvUn oK9f7M/o9uL3TccZ1W1udxEpHiP8A0H519K4dw604XbLbWNvHDGOidT3J6muDn8/Dj6x7rzy5JHjPZ79HVtbBZ+NOJpeYhQ+QfHvXureGK2iWK3jWKNRgKgwBU+RzRz2/hX4/Lz58t++ue5WgbDFX2SLLeQI5AVpBqJPTO9XWtiLjwT4hCuxV20+5gA/zro4bIwCqcvqcNqIAVQcAn4mmPFl1UkpW4mNxcSzYI1uzfDJqunDwu80yMYgGTIKs4yxHPHe uXtmbbDBvI2NOSMnbfbtWbx5zuxbKUooorzZFFFAoq22lMFzFNkjQwbb0NaCcUBhkUtIpLOR pAOoNy+FVQxW4trdpLfXJIsrE+KR7gJA25Z5fOmbWwt57kARr4TIhKguSpOeWOm3M7V1cczx mpWptFeIwDwPDjZRE5kOO2nGM1kDkNyfU1rxQLHaXEkcOsNauTOS3PPu45dP98qq4naQ20eI IZdnAEpGFdccwdRz8gKcmOWU3Sy6ZtFHworlYFFFFB8hbLs005LStuuelWwReIPEljkaEOol Ma5IGfShI0QCWZtKL72++P9g78u+K5dXIVgkBICgqGDNnBPug7ZHy+Z519g7VF8LYxIiRokk R0NMj5WXfY4PI9/jXYri0tb17S9jMUOvEVyBnpvq9M0tAnj3AJGIocZ9Xxy+Q/jWg0cU0ZjeLWGGKsDF5ZyQYLKGRvMjLurDuDVEKAb4AJ78qrsrybgcbQ3Cvd8Kc8vvQnqRn/inrqAKI5bZw9rNvE68iK10hYR+UELnJI+GP+fzpXiFwtocytl8e6Otd4hxP7IPBhIeU+9jkv x9a81dzs8hZ3LMedYyq6F5dSXL6pT8F7UsSTXDvQKyrlFTRWY4Ub1YUWPmct68qaFSoTyHzq zQBz3b06V0FmGAQoAzk17L2S9hp+KLHd8REltZHcAjEkvy6L6868uTkw45vKpbJ7YXAOA3vG 5jHZxBgD5pGGET1J/lX1T2b9krDgaLJj7ReY80zj3f8I6Ctm0tILGBILSJYoVGAFGwq+vxPJ87Llvxx6jny5Lehz5 0dc0UVwvIUUUCgvhumitpLcKuHxkk+78KYPFZGld2UBGjCMqOV5dcjrn+NT4fcRxQRRsYsEy GTxFBPIY6d6utp4HnSaSWFZDEnijyqCfvcwR8gN66cd6msnp+S68QllR4RESfOwAlYaQeefx d96ourw3ICuq5XAU9QMcqdilhjikSOW3SLTKrJjzscnTjblp09e9R4lNA9mi2/2cxgjQVY6xtvkY2+tay7w7yLvXtl0UUVyMCiiigKKKKuwUdMdO1FFN1BRRRUBRRRQfI57q5t y6Sqkcq4Usjb+oII68/QnbFLIhmy5HmxtnvUN5p/EOSOmabiHQb57V9jHajAixRKi7gHzMebHufnT8EQZsquFxVUCas5AwO9Ne7nB0jFVlGRkTI0 5BG6nrWQnEpeEeLa2yrPaz5LwSe7G34gehqd9e4cxxOGkHNuePSsO9kwfBjDPI25NYtaiqZg/m8RNyRucnalmjHMOrfCpNFp2Y79+1cUIhy41bcqiuaQu5rqxl2AxseVSji1EM+FUdWPOr/FRPIik+vegCngpvy71VDDLcTLHChd3OEVRkk01Y2d1xK8S2t4Wnnf3UG317Dua+teynspb8C i8WXTNfuPPJjyp6L6evWubyPJw4Z37Zyy+LL9kvYiOyEd5xdFluRhkhO6oe57mvbUfGivwOX mz5ct5Vy5ZW0UUUV4siiiigKKKKAoooooooooCiiigKKKKIKKKKAooooCiiigKKKKD//Z[/img].
Old 02-08-2018, 02:23 PM
LexVan
LexVan's Avatar
Most owners will say <5 years. The Owner's Manual will say < 6 years. The manufacturer will state 10.
You could always ask the Paul Walker estate. RIP.
Old 02-08-2018, 02:35 PM
Marine Blue
Tires will start to harden at 3 years when heat cycled and by 5 years they lose a good amount of their traction. My original Bridgestone were physically perfect when I had them removed but they felt like ice skates, very slippery in the corners and during harder acceleration.
Old 02-08-2018, 06:38 PM
Benjamin Cherry
Benjamin Cherry's Avatar
One question to consider would be whether you are interested in forming a relationship with your local Porsche dealer. If you are, it may be worthwhile to consider having a "major" service (air filters, oil change and filter, spark plugs, brake fluid) done in order to establish a "maintenance baseline."
I recently did this for my 981 and am happy that I did.
My point of view is not so much that this is going to win you big discounts on parts or service down the road, but it may foster honesty with respect to the assessment of your car (i.e., not trying to sell you a bunch of bologna the way they might if you come in new off the street with some sort of repair issue) -- probably far more valuable.
Old 02-08-2018, 06:42 PM
Benjamin Cherry
Super cold comment, but thank you, because 1. I didn't realize that tire condition was related to his death, and 2. a search led me to this interesting article:
​​http://www.thedrive.com/opinion/5189/the-truth-behind-what-caused-paul-walkers-fatal-crash
Old 02-08-2018, 07:18 PM
Van Larson
Van Larson's Avatar
Default Maintenance
I purchased my 10S with 4800 miles 1 year ago. It had annual oil changes and 2 year brake fluid change I did everything you mentioned except plugs. Concern was ability to remove w/o problem. Took 1 out on each bank--new condition. Retorqued and will wait to 15k. Also replaced tires and tpms due to time.
Old 02-08-2018, 07:31 PM
Dave in Chicago
Dave in Chicago's Avatar
All fluids, tires, align, then drive it like you stole it. Only way to baseline fluids (coolant, brake, trans, oil) is to do them.
All other items should be okayed via inspection. Enjoy!
Dave
'05 987S
'92 968 SP3
'88 944 NA (gone)
Old 02-09-2018, 09:29 PM
sweinland
sweinland's Avatar
Thanks everybody for your input. In response to some comments....
Why alignment? - The steering wheel is 5% off center. I was initially concerned that this may reflect that the car had bumped a curb or something. I purchased the car from Carmax so don't know if it was on a car carrier or any of the history. I thought that alignment would be important to preserve tires - but with the number of folks telling me to change the tires I'm less concerned with the current set I guess. I haven't noticed any traction issues yet and it drives as if it was on rails. But noted and I'll work on replacing the current set.
Why not change all the fluids? Understand the sentiment here. I'd love to, but I'm not your stereotypical owner. I bought my Boxster from Carmax and don't have a lot of extra cash - so I'm trying to be frugal and not waste fluids that are perfectly ok and don't need changing. I'm a psychologist and not an engineer - but I also know that there are knowledgeable folks here - so I posted the initial question to the group with hopes of being educated. Mission accomplished - thank you everybody.
I thought that brake fluid had hydrophilic qualities and can go bad over time - so changing it makes sense to me. Plus I've got a pressure bleeder system so this is another easy one to do at home.
I'm still unsure if the transmission & differential fluid need to be changed. It's supposed to last 50k miles and I'm not sure if it has the time component to changing. BUT I have heard that the car needs an alignment after you change the transmission fluid so figured I might change it anyway.
Thanks everybody for your input. It's an amazing car and I'm really looking forward to spring and summer months with it.
Quick Reply: This car sat... what services would you do first...
