981 Spyder Interior Cover - Coming Soon!
Yea, definitely looks off in a Mondial-ish sort of way! LOL
Possibly, but even then you would need to somehow secure the cloth that extends back further, right? You wouldn't want it flapping around. And I personally don't like the idea of the wheel well straps on the paint of the car.
If only the 981 had your 987's red clamps in the rear clamshell, all would be solved. They would be the perfect place to secure the rear of the cover.
Ok, so . . . umm . . . this is the first prototype of the Spyder interior cover proposed by Covercraft. They provided it to Jerry for his use and feedback. Like me, Jerry finds the cover to be awkward in appearance and not of a design aesthetic that does justice to the Spyder's sensuous lines. As suspected, the lack of any possible adherence points on the smooth rear deck lid poses design challenges that make the rear wheel wells the only option for securing the back of the cover.
The current thinking is that if the rear of the cover came back bimini-style over a portion of the rear lid and did not end abruptly behind the roll hoops, it would greatly enhance the appearance and if the cover could maintain to a great extent the profile of the roof when raised, that would be preferred.
On a more positive note, according to Jerry the quality of the material is top notch and the install is a breeze.
To Covercraft's credit, they agreed to entertain design changes so Jerry headed back up to Canoga Park last week (for a third time) to try to get the design sorted out. It's a 90 mile drive one-way from south Orange County to Canoga Park in soul crushing Los Angeles traffic so to say Jerry has gone above and beyond is an understatement. Thanks, Jerry! And hats off to Covercraft for their willingness to start fresh with a clean sheet and go at this project anew.
Will update when the second prototype is complete for those who remain interested in a custom interior cover for the Spyder.
For the rear attachment I would recommend you get the Porsche part that clicks into the rear and sew the fabric to that. (You might need to have that part fabricated however since it's probably not available as a separate part for purchase.
Walt
Walt
Nice project though, hopefully something worthwhile materializes for all the effort that is going into the project. Definitely have some interest in getting one...
https://www.ecstuning.com/b-genuine-...e/98156790900/
Get a pair of them while you are at it. cough cough
Update: Version 2.0
Well, here's the second prototype Cover Craft has come up with for the Spyder interior cover:
It appears the main change from Version 1 is an extension of the material to which the rear straps are affixed. Version 2 has essentially grown flaps (sort of) extending over the back clamshell, which can be seen when compared to Version 1, below.
While stylistically Version 2 may be a (slight) step in the right direction, I'm not sure I'd pull the trigger if this ends up being the final design.
Looking good! I need one. Any way magnets could work? This would eliminate most of the straps? For indoor storage you wouldn’t need to use any fasteners...
There are no bad ideas at this point!
I keep mentioning an alternative to the rear straps but it seems my comments go ignored. If you look at the cover I posted pics of, you will see that it slips underneath the forward edge of the clamshell and gets clamped into the rear cargo area when you close it. This keeps the cover taught and difficult to simply walk away with if you had bad intent. Sewing some type of tubing into the rear edge of the cover, when clamped into the rear cargo area, would make it darn near impossible to walk away with and would keep it fastened even in high wind.
Not in MA anymore
Matt
For me personally, I don't think it looks great to have the cover end abruptly behind the roll hoops versus extending back buttress-style mimicking perhaps the lines of the 987 Spyder's bimini-type sun shield. Is your cover functional? Sure. Does it do its intended job of protecting the interior? Absolutely. Does it look great? I guess that's my issue (and I know looks are entirely subjective). The Spyder is so damned sexy that it deserves more than just a functional solution IMO -- it should look great as well.
Well, I'm on record as not being a fan, but I don't want to offend the good folks at Cover Craft. When approached, they were totally receptive to the idea of creating a custom interior cover which, given the Spyder's limited production, would generate limited demand (and thus limited profits). They could have run the idea by their bean counters, laughed, and said, "Are you kidding?" Then they put in the time and effort to design not one, but two prototypes, when asked to go back to the drawing board. Gotta give them huge props for that.
Didn't mean to ignore. Like I said, no bad ideas at this point. The set up you describe with the rear of the cover having, for lack of a better word, "tabs" that secure the cover when the clamshell is closed over them is the same set up used on the Z3 interior cover pictured above and it works well with that particular short/stubby trunk lid.
