Spark plugs for 981 Boxster S
I've been searching for the past 45 minutes and can't seem to find out what the OEM Spark plugs are for the Porsche Boxster S (2013). I'm looking to order a set. Does anyone know which Spark Plugs work?
I found that link as well, but am curious to know what actual plug they're using. (copper, platinum, iridium, gap, etc..)
Location: On a pygmy pony over by the dental floss bush
The OEM plug is made by Bosch, has 4 electrodes arranged 90 degrees apart around the central insulated electrode. Go to the Bosch website and get their part number for your car, then ask them about all the details you are interested in.
Looks like the part number is FGR 5-NQE-04.. which make them a "copper plus" spark plug. I had always thought the lifespan of a copper plug was only 10-20k miles. Surprised Porsche says to change every 40k or 4 years.
I just changed the plugs in my BS at 26,000 miles but only because I was doing a header install and it was convenient to do them at the same time. They all looked clean with little electrode wear visible, nice color from normal combustion.
I did the same at the same miles (headers/plugs), albeit in an older 981S, 2014 (26k miles) and the plugs looked terrible. Corrosion on the threads and a hint of oil on some threads, with jet black electrodes. The car has seen a few track days and the plugs were at the 4 year spec to change.
Thanks. Im going to change mind for peace of mind.
