ABS sensor connector
I managed to break the clip on the ABS sensor connector on the left front while doing a pad swap. The sensor is fine, and the connector has held on for a few drives with some zip ties, but I want to make it back to OEM. I can't seem to find the connector in the PET. The sensor is 99160640701, and is fine, but I want to replace the connector that latches on 99160640701. Does anyone know how to do that?
Location: On a pygmy pony over by the dental floss bush
Thanks. May have to do that. The only complicating factor is there is no dealer in the city I live in. The little plastic piece in the middle of the connector is all that broke off, so it may even be repairable by someone with more skills than me.
Did you ever get a resolution to this? I did the exact same thing, broke the little clip on the left front. I've used safety wire to hold it on for now.
This one comes with extra oarts if needed but takes some time to come in cine its from ebay, CLICK HERE
But i ordered mines from HERE came in fast and fixed it.
The harness costs $200 and takes time to come in, this saved me!
***EDIT*** i noticed this is for the ABS sensor , mines was the brake sensor clip broke from the harness side feeding into the car, and not the brake sensor it's self, but if you look at the end clip, if it has a part number you can find it (google ). and perhaps do the same as i did and replace that end alone. good luck.
Still working on it. I put 5k miles on with the safety wired/taped connector and it's been fine. I believe the only way for a shade tree guy to replace would be to replace the entire harness for that hub, which appears to be 99160913101. I ordered a used one. This also seems to be the exact part we broke, but the seller does not ship to my state (item in Wolfsburg, DE): https://www.ebay.com/itm/2x-15cm-Rep...2zQ:rk:10:pf:0
I ended up ordering the clip from the ebay link you sent. Thanks for posting that. Basically you have to email them so they can send you a link on how to purchase with shipping to the US (the initial link denies all shipping to the US). I will post back if it works out. For that cost it's certain worth a shot.
Update so folks can see how you fix this. After 14 months of it being zip-tied on (which held up fine) I finally got the replacement harness and fixed it the right way. The harness is 99160913101. It is self-contained, linking only to the ABS/wheel speed sensor and the brake pad sensor (which, on my car, is zip tied to the strut). Replacement is pretty self explanatory once you remove the entire front fender liner, which is a bunch of torx screws including a few under the bumper cover. The most in-board connector, which links the sensors to the main loom, is a bitch to get off since there is very little space to work with. I used a finger nail to get it open. Pics are more useful:
Thanks for posting. I've not fixed mine yet (with the part I got from ebay), but will post when I do.
Gah, i just broke my right rear wheel speed sensor connector. Looks like the pad sensor, wheel speed, and parking brake are all integrated into one harness. Doubt that's cheap. The connector PN is 6E0 973 702. Looks to be readily available so i'll swap it. Hopefully i can extract the pins and just swap housings.
I fixed 2 of them yesterday the connector is listed below you can get them with out the wires in them (just the raw connector) and if you get yourself some terminal repair Key tools you can remove the wires from the old connectors and put them in the new connectors. Just document the orientation of the pins and the wires in the connectors. The back connector was harder to get the wires out of but I was extra careful to not pull to hard on them, The front connector was much easier.
