Checking oil level
Checking oil level
My Porsche "Good to Know" phone app says "The oil level can be checked after waiting for approx. 1 minute with the vehicle parked on a level surface and the engine at operating temperature." I does not say if the engine can be running or shut off. The oil level seems to read the same either way. My old school way with aircooled was engine at idle, warm and level.
My service guys do it with engine off. What do you do?
Would rather have a dipstick vice electronic measuring.
I do it engine running, normally I would agree with you on the stick but the path on the 986 was so torturous that getting a good reading was tough; probably why it's electronic now.
987.1 engine cold, before starting
987.2 engine warm, idling
981 engine warm, 1 minute after turning off
981 clearly says engine has to be off, and exactly 1 minute after shut-off is better, for consistency... as well as same flat surface (garage, etc), and same oil temperature. That way, everything will always be consistent. Noticed I didn't say accurate, since each segment equates to 0.45-qt. I've never had any issues with such sensors. I much prefer a dipstick, but once you understand how the sensors work, no issues.
All cars I've owned with electronic sensors throw a number when oil reaches enough temperature to trigger the sensor (including my 981 GTS). Sometimes level stays the same after a proper check, but sometimes not. Bottom line is you shouldn't rely on that. Always force a reading the right way, and you'd know where oil level really is. Or at least within 0.45-qt.
In regards to checking the oil level on a 981. The reading is always available engine running or not after the vehicle has reached operating temperature and has been shut off for about a minute. That reading will be available anytime engine running or not until the engine is run again and reaches operating temperature and then it will be replaced with the new reading. The only time the reading is unavailable is if the rear hatch has been opened for more than thirty seconds. This will cancel the reading as additional oil could have been added when the hatch was opened. You will not get a reading until the engine has again reached operating temperature and turned off for about a minute. If you never open the rear hatch you will always have a reading from the last time the vehicle was at operating temperature and turned off.
dadster (12-31-2022)
Mine throws a reading when oil reaches operating temperature (before shutting engine off) after opening the hatch. If the car did that by itself, it wouldn't say in the manual how to do it, IMO. But my car definitely throws a reading once engine gets hot enough, just like BMWs and others. Whatever the car does, do it yourself like it says in the manual and call it a day. I don't pay attention what the car says except when I reset it myself.
Location: On a pygmy pony over by the dental floss bush
Check this post I made in the GT4 forum and read the 2 page attachment I included in that post. More info than you ever cared to know about oil level display in 981 cars.
https://rennlist.com/forums/gt4/9942...ailable-2.html
Thanks for that document. You should post it here. It checks oil level both ways (static and dynamic), but it's better to do it statically (more consistent). Based on that document, the best way to check oil level IMO (which I'll do from now on) is to open the hatch for a minute (>45 sec) while engine is at typical operating temperature after getting home (about 195ºF, in my case), to erase previous oil level info. Check that oil level info was erased, close hatch, then start engine and shut it off. If engine is cold, it'd throw a reading around 158ºF or so, which is not the same as 195, hence I wouldn't rely on a 'dynamic' level check, but to each his own. Apparently the system waits a minute before measuring level, so we CANNOT really force a reading ourselves. Interesting. The manual clearly says to wait a minute before checking level, but what it doesn't say is the DME is doing the checking automatically, which takes a minute, hence waiting a minute to see the results, I guess.
911 Chicago (03-08-2021)
I just changed my oil at a small independent shop but they were not able to get the service indication changed on my 981 Spyder. They have the Computer for Porsche diagnostics but told me that Porsche is not allowing independent shops make changes to the service reminder. I still show the change oil notification. Anyone run into this and is there any way to fix this without paying the dealer $450 service charge?
