Sponsored by: APR
Spyder brakes - rotors and pads?
Old 06-28-2017, 10:04 PM
Dalema
Dalema's Avatar
Default Spyder brakes - rotors and pads?
My pads need replacing. Has anyone out there replaced their 981 Spyder brake rotors and pads with anything other than OEM?
I was thinking of the Girodiscs for the rotors - but not sure which ones would fit. Expect it would be the 991 S replacements?
How about pads - if contemplating a little track time would the Pagid yellow be the way to go or just make too much noise for everyday use?
Did they use the 991 S brakes on the front and rear, or just front?
Old 06-29-2017, 11:32 AM
Dicknose
Dicknose's Avatar
Just the front. Rears are base 911.
Also interested to hear what others are doing.
I put stock on, but I needed replacements quickly!
Now I should shop around while I still have time.
Old 06-29-2017, 05:46 PM
Dalema
Dalema's Avatar
Actually Suicide Jockey just replied on another thread:
991S brake specs here:
http://press.porsche.com/vehicles/20...ifications.pdf
Spyder brake specs here:
Rotor diameter front and rear is the same on both cars if you do the metric-to-inches conversion.
Old 06-29-2017, 06:15 PM
981spyder
981spyder's Avatar
only one that I found was yellow stuff guys, I emailed Hawks they said they should have something out soon. ;-(. The 911 991 GTS 4 uses same brake pads.
Old 06-29-2017, 07:25 PM
Dicknose
Dicknose's Avatar
Pagid list the rears as 4918
http://www.pagidracing.com/product-s...hape-4918.html
That says it's shared with non-S 911
Fronts are 4922
http://www.pagidracing.com/product-s...hape-4922.html
They might be wrong, but this would based on calipers/pad shape rather than disc size.
Old 06-29-2017, 07:26 PM
Dicknose
Dicknose's Avatar
Anyone know the OEM pad part numbers and if they are shared with other models?
Old 06-30-2017, 06:49 AM
Ddesimone17
Ddesimone17's Avatar
Check this website best prices , I just replaced all four corners w Oem
https://stores.revolutionparts.com/g...nt-brakes-scat
Old 06-30-2017, 04:27 PM
Dalema
Dalema's Avatar
I connected with Girodisc and if anyone is interested in their part numbers:
"At any rate the 981 Spyder actually used the 991 C2S brakes which is our p/n A1-122 in the front and A2-032 in the rear and a 350mm upgrade at all four corners."
I'm likely going to go with these, just need to figure out the pads.
Old 06-30-2017, 04:36 PM
Dalema
Dalema's Avatar
I think the pagids would be definitely worth it on the track, not sure they would be okay for daily driving though - wonder how squeaky they are?
Fronts are 4922
Maybe the S/non-S 991 rears are the same then? Fronts definitely different.
Where abouts in Sydney are you - I grew up in Cronulla?
Great resource - thanks for the link!
Do you have to replace pads and rotors at the same time, or is that some made up stealership BS?
Old 07-01-2017, 04:10 AM
Dicknose
Dicknose's Avatar
Don't have to, but for me the front rotors where starting to crack so they needed replacing.
Sydney - I'm north side, so I rarely get near Cronulla.
Old 07-01-2017, 09:05 AM
PCarOMFS
PCarOMFS's Avatar
OP, I had Pagid yellows on my Cayman GTS and used them for track and street. Having said that unless you're planning on a lot of track time I would stick with OEM pads. The main benefit on track was better pad wear of the yellows. They are very noisy and annoying on he street. I felt braking performance was similar between the two.
Old 07-01-2017, 09:13 AM
Ddesimone17
Oem are inexpensive and are fine on track that's what I use just change them often no big deal
Old 07-01-2017, 03:16 PM
Dalema
Dalema's Avatar
Thanks. Just how many Spyders made it to Australia?
The price of cars is definitely a benefit of living in the US.
Old 07-01-2017, 03:21 PM
Dalema
Dalema's Avatar
Thanks guys. The OEMs sound (no pun intended) just fine then for my needs.
Old 07-03-2017, 04:09 AM
Ddesimone17
As far as I can tell it is total fiction
Quick Reply: Spyder brakes - rotors and pads?
