BBi Autosport 987 Cayman R StreetCup build in Hong Kong by WanTune
Basic Sponsor
Attachment 1344394
BBi Autosport 987 Cayman R StreetCup Build in Hong Kong by WanTune
We would like to present Wantune's BBi Autosport 987.2 Cayman R StreetCup Build. To improve handling and power for the track, Wantune installed our BBi Track Suspension and Power Package with components from Cobb, Tarett, and IPD Plenums. Located in Hong Kong, we are proud to have Wantune as premiere distributor in Asia, representing our complete line of performance and safety upgrades.
Power Upgrades
Suspension
Fabspeed Race Headers & Supercup Exhaust System Installed
BBi Autosport Porsche Cayman StreetCup Suspension Package
BBi Street Cup Common Features:
BBi Autosport Front & Rear Lower Billet Control Arm Kit
BBi Autosport Front Bump Steer Kit
BBi Autosport Rear Adjustable Toe
BBi Autosport Front & Rear Thrust Arm
Tarrett Front and Rear Adjustable Sway Bar End Links
About Wantune
Facebook: www.facebook.com/wantunehk/
Email: travywan@gmail.com
International shipping is available and wholesale inquiries are welcomed. BBi Autosport products are also available worldwide through our growing dealer network in North America, Latin America, Europe, Middle East, Africa, Asia and Pacific. BBi Autosport is always actively working to expand our dealer network worldwide to grow the distribution of our products and better serve our growing client base. For all questions and inquiries, please email Jerry@BBiAutosport.com or Sales@BBiAutosport.com
Power Upgrades
- Cobb AP
- IPD "Competition" Plenum
- Fabspeed Race Headers & Supercup Exhaust System
Suspension
- JRZ RS One Coilovers (include camber plates and custom spring rates)
- BBi Bump Steer Kit Front
- BBi Adjustable Thrust Arms Front & Rear Pairs
- BBi Lower Control Arm Complete Front & Rear Pair
- BBi Rear Toe Adjustable Toe
- Tarett Engineering Adjustable Sway Bar End Link Front & Rear
- Hard tested on the street and track
- Provides additional adjustment range
- Helps maintain proper suspension geometry
- Utilizes turnbuckle design to be lengthen or shorten links to desired specifications
- Eliminates factory rubber bushings for improved suspension feedback
- Direct bolt-On replacement and requires no modification to the vehicle
- Made of precision CNC machined 6061-T6 aerospace grade billet aluminum
- Precision Teflon lined spherical rod ends for smooth operation and long life
- Discrete black anodized finish for increased corrosion resistance
- Made in USA
- Improved two piece 996 GT3 lower control arm design
- Stronger than cast motorsport Cup arms
- Allows proper camber adjustment 996 & 997 Models
- Uses GT3 shims to adjust camber & lower control arm length (sold separately)
- High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
- Sealed monoball inner bearing
- Allows easy access to inner arm hardware
- Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
- A must have for all track and race enthusiast
- Each kit includes pair of 2 arms
- Fits both front and rear axles
- Helps eliminate bump steer by maintaining proper front end suspension Geometry
- Utilizes misalignment rod ends of the arm to provide maximum articulation
- Highly recommended for vehicles that have been lowered
- Each kit includes pair of 2 Links
- Provides additional rear toe adjustment
- OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
- Helps maintain proper rear end suspension geometry
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Each Kit Includes Pair of 2 Links
- Simple bolt in replacement for the factory drop links
- Left & right hand threaded rod-ends allow for simple length adjustment to eliminate swaybar preload
- Correctly sized, precision, Teflon-lined rod-ends for smooth and quiet operation, long life, and high reliability. No wear and rattling problems, like those seen with other designs, due to undersized or low quality rod ends
- Eliminates the factory compliant plastic drop link bushings that deflect under loading and quickly wear out
- High misalignment, stainless steel spacers allow for superior bind free operation and corrosion resistance
- Precisely connects the stock or adjustable swaybar to the front strut assembly for improved feedback and swaybar response
- Overall length is adjustable to accommodate either stock or adjustable swaybar requirements
About Wantune
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
