987.1 relay location
hey guys, i'm hoping someone can help me. i'm trying to figure out whats happened to the soft top on my 2007 Base model. I'm thinking its a relay but can't find the damn thing. a little background on the issue. bought the car with the understanding that the soft top didn't work. i've ordered a new motor thinking that may solve the issue, sadly it didn't. replaced the microswitch at the front latch assembly with no luck. When i check to see if the motor is making any noise or vibration when i push the switch i'm not getting anything nor do the windows dip as they would normally do when you raise/lower the top. that leads me to think perhaps the Relay has gone bad but the only thing i can find is the relay box for the 986 which is just above the fuse box in the drivers footwell. can anyone advise me to where i might find this elusive beast? or if you have any other ideas on the soft top repair, i would be eternally grateful.
