981 PSE questions (parts and compatibility)
Hi, looking for a used PSE for sale and had the following questions for different scenarios I may find them under:
1. Is the exhaust the same for both the 981 Boxster and the Cayman (the part numbers/SKUs on Suncoast would indicate not but wanted to check)?
2. Is the exhaust the same between the 981 2.7 and 3.4 liter engines (the part numbers/SKUs on Suncoast would indicate YES but wanted to check)?
3. Are things like the button for the console, vacuum lines for activation, etc. available individually?
Any insight/guidance is appreciated, thank you!
Dom
Dom
