Check Brake Light
Check Brake Light
While out and about on Saturday, I stepped on the brakes and the warning message "check left brake light" appeared on the dash. I headed to the local Auto Zone and had my wife get out and check when we stopped in the parking lot. The left rear brake light was indeed out. I bought a set of replacement bulbs and switched both the left and right bulbs out when I got home. We checked and they both worked. However, I got in the car this morning and now have a two warning messages saying to check both the left and right brake lights. Both are working. Any ideas?
It could be -- I hope not -- but it could be similar to the service engine soon light, or warning that appears when it is time to change the oil, and the brake light warning needs to be cleared at the dealership.
I would have thought the light and warning would have not come back on at the next engine start. Perhaps it takes several of these engine start events for the warning message to go away on its own?
But check the manual. it might just be a sticky warning, but it could be a real warning that something is still not right.
Sincerely,
Macster.
The check brake light warning does not have to be cleared by the dealer. I just changed my brake light bulb and the warning message went away instantly.
Are you sure you used the right bulbs? If you kept the other good bulb, try putting it back in and see if that makes a difference. Also, make sure they are tight in the socket.
Check it with the old bulb. It has the number stamped on it. I don't remember the number anymore, however, I do remember that when I got mine (from Advanced Autoparts) they had the wrong bulb number in their computer. After I got home and took the old one out, I realized they were different and had to go exchange for the correct ones.
I just found my reciept. You DO in fact have the wrong bulbs! The bulb you need is 7225.
As it turns Advanced Autoparts made the same mistake your store did. they originaly sold me bulb 7528 also. I also looked it up online and everywhere I looked also showed the wrong bulb.
I called my local dealer last night and left a message about this, in case there might be some obscure reset procedure. They just called back and said the issue is the aftermarket bulbs have a higher resistance which the system interprets as a fault. Since I've only got 19K miles on the car, he said the bulbs are still covered under warranty, so I'll stop by there on Saturday to have them swapped out.
I would definately use the OEM's if thats an option for you.
However, for others, mainly those who can't get OEM's from the dealer, the 7225 bulbs fit and work perfectly. DON"T use the ones in the autoparts store computer.
Pelican also has it wrong
I tried to get the correct part from Pelican, but even they screwed up and sent the 7528 lamps. I eventually found the correct part (7225) at a local auto parts store. So much for ordering from so called Porsche Experts on the internet for such simple things as lamps. I figure they just scrape the Sylvania website which is not the same as verifying a part with the manufacturer's documentation.
Cheers,
-Cyborg
Cheers,
-Cyborg
Advanced auto is still selling 7528 bulbs instead of 7225 for Porsche
Couldnt figure out why the light didnt go away on my 997, glad I checked here. Off to Advanced auto to swap them out for 7225s
That is frustrating, after all this time you would think someone would make the effort to correct it so they don't get a bunch of returned bulbs.
Message wont clear
Hi all, I also got the "check the left rear brake" message. Fitted a new bulb and they are both working fine however I am still getting the error message.
Any ideas why the message is not clearing ? thanks.
Yup, still ran into this today with my local NAPA. When I installed the bulb he got from his system I still got the error message. Then when I brought him the bad bulb he cross referenced it and got a different number. Once we used the cross referenced bulb it works great and the error message went away.
