981 OEM rear camera retrofit
Hello,
Maybe someone knows, what parts i need for retrofitting OEM rear camera?
I already have:
Camera: 95B.980.551.H
Holder 1: 981-642-222-00
Holder 2: 991-505-899-00-1e0
Holder 3: 991-505-901-00
What else parts i need?
I already have:
The most intriguing and factory-like option I've see so far is this:
https://www.maxspeed-motorsports.com...ERSION__2.html
Registered User
After several months of research and reading others experiences, I'm leaning towards this package:
https://navtv.com/products/NTV-KIT375/pcm31-xg-cam.html
One feature of the Nav-TV unit is it allows me to add a front camera at a later date, if needed. Also, it doesn't require a trip to the Dealer/Indy to have the PCM coded for use.
Of course, I would definitely consider an OEM kit if it ever became available.
https://www.amazon.com/dp/B00P914PMY...X61A9V0Q&psc=1
I've got the Pearl Vision rear camera which works great, however some guys have had difficulty with it.
I'd definitely cheque out Maxspeed motorsports set up on the rear camera system. Do a search on Rennlist.
It's an OEM set-up that they figured out to "retrofit" PCM so back up camera appears on screen. NavTV products are also good, I've used their stuff before.
Thanks all for replays, but i will not go with aftermarket products like maxspeed as there is no way to use OEM camera with them.
I am still looking for the info and i will do OEM camera retrofit.
If someone has info related OEM camera, please let me know.
I have also find some interesting harness (right), need help to identify code:
It looks like we need this part and we ready to go!
Have you located the part number for the license plate light/camera holder? That can't possibly be one of the $10 parts you identified by part number above.
I am buying those harness it is custom made to work with OEM camera and PCM 3.1 + you need coding to active camera.
p.s no need any extra video modules just OEM camera, harness, coding = joy!
Those are camera holders, you need all of them:
Also you need to cut hole or get bumper with camera hole.
Which software version of pcm3.1 is needed? My pcm3.1 can’t go beyond 3.43 and all of the nice camera mods require 4.xx or whatever. Very incredibly frustrating since a newer pcm3.1 cost $4k.
Registered User
Registered User
https://rennlist.com/forums/991/9104...l#post12889738
