How do you drive your 987.2 Spyder at the track?
I've done literally thousands of miles on the track in Spyders. Mostly with the top off but also with top on.
The only harness bar I've seen for 986/987 Boxsters is a generic bar cut to length from SafetyDevices. I got one for my 986 from Stable Energies. I had some difficulty getting the harness/HANS geometry right. Had to lower the seat and add the B-K roll bar extension to get my head/helmet low enough. In that position wrapping the shoulder harness on the factory roll hoop crossmember the harness angled down from the bar to the shoulders which is not recommended by Schroth or HANS. With the harness bar I could get the shoulder belts horizontal.
Happy New Year everyone!
Thanks for the great info on the harnesses. How do you all mount the lap belts? It does seem like the roll hoops are too high to mount the shoulder belts. If anyone has photos of a harness bar installed, mounting points, etc. that would be great to see and learn more about anyone who makes them. My car has the LWBS, and the shoulder harness pass-thru holes seem to be the right height, so ideally I’d like the shoulder harnesses to be level with those pass-thru’s.
Great, thanks for the additional info! I’m a fairly experienced driver (white in PCA) and also do a lot of my own mechanical work. Will look into these options. The lightweight buckets are not that familiar to me, and I don’t have the car yet, so I am not sure what the seats Support in terms of mounting points for the lower harnesses.
