Hacking the GTS Synposium Sound system ?
It is ENHANCED man. Look at the plunger-type cone near the valve. It's like a speaker, with a membrane inside to amplify sound, so basically a mechanical speaker.
It is my understanding only the CAYMAN GTS has the symposer, not the Boxster. Find out for sure before cannibalizing your car.
Sure, the membrane affects the sound character in some way, much like a piece of cloth in front of a speaker would. But once there, it's there, it's not an active part of the design.
Further upstream, there's the control valve which is open/closed depending on engine speed (and maybe load) and driving mode (NORMAL/SPORT/SPORT PLUS)
Cam07 (02-10-2024)
The membrane is to seal the intake indeed, but the cavity to amplify the noise. How do you think a guitar works? Otherwise it'd be just a straight tube. I believe the Porsche literature even spelled that out. But yes, it's more acceptable than a freaking speaker, but equally annoying to me.
And in any case - as you know - I totally agree with you that whatever enters the cockpit that way is massively annoying - hence my plug
Looks like the part numbers that are needed are 981 110 028 00 and 991 110 282 03
i cannot not tell if these will connect up to the intake or not. I don't see any other different part numbers except the right snorkel where the last number changes on the PET but not according to sunset's PET. 981 110 212 02 (Sunset PET for GTS) and 981 110 212 03 (for the PET above)
It seems you're planning on after-installing a symposer in your car? Did you test drive a GTS and decided that this is the sound character you want?
If so - just a friendly reminder - the symposer is controlled by a vacuum actuator + electronically controlled valve (which is controlled by the ECU). An S will most likely not have either the SW nor the connections or vacuum hoses in place needed for the system. Even if you plan on having the system sitting "passively", I would guess the vacuum actuator is closed default (spring loaded). Hence you would have to force it always open.
IN THE 60'S flipping the air cleaner lid over made noise too.....but it got old real quick....kinda like base ball card or balloons in your bikes spokes ......sound sym...poser ...good grief .Ironic it seems a lack of oxygen thought this idea/option up
Richard 'borrowed' a photo of my post on P-9
http://www.planet-9.com/981-cayman-a...ml#post1853361
There are two issues: I believe one end of the symposer connects to the air cleaner as there is a different right side air cleaner for the I155 symposer option. This may require removal of the engine to remove/replace (from factory service manual). Option 2 is to modify the existing one in place. You'd need to drill a hole in the cleaner at the proper spot and put a mating flange/coupler in the hole. Hopefully there is room to do this.
The second issue is the vacuum valve connects to the PSE vacuum switch (aka electronic change over valve). If you have PSE, then it is just a T and some vacuum line. If you don't then either you can hard wire it, but I am not sure if on is with vacuum or not.
Right air cleaner part is : 981-110-214-01
The three parts are not that expensive, under $300 for the bunch.
V6
V6
