981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Headlight alignment
Old Mar 1, 2026 | 09:49 AM
srb1194's Avatar
srb1194
Default Headlight alignment
Greetings everyone,
I have searched for an answer to this and can't find the answer. My car is a 2014 981S. I do have the self leveling Bi-Xenon lamps on my car. I seldom drive this car at night but I went to a local event last night in the car. To my surprise the vertical alignment of the headlamps was way off on both sides. Basically I could drive with the high beams on without bothering anyone I met or followed. So I have to go back and think what has changed since I last drove the car in the dark.
The only two things that have changed are the addition of the X73 suspension and a recent PPF replacement on the front of the car. So I'm thinking the suspension would only slightly change the rake of the vehicle but perhaps this is not correct. The headlamps were removed for the PPF application.
When I start the car the lights perform the self alignment and seem to work normally other than the vertical alignment. From what I have read the base setting is adjustable and might be the answer. Could someone provide guidance on the best remedy for this situation.
Thanks for any feedback!
Old Mar 1, 2026 | 11:12 AM
ShiftyWolf's Avatar
ShiftyWolf
See if the attached info is what you're looking for.
File Type: pdf
Old Mar 1, 2026 | 12:15 PM
srb1194's Avatar
srb1194
Well that's super helpful and much appreciated. I will say it also seems very complicated. I'm now wondering if I should have a professional do this or give it a shot on a garage door. I'm a little worried about screwing something up.
Aside from tool, which I have, all I have to work with is a garage door. I do not have an alignment tool. Has anyone successfully done this without the alignment tool?
Thanks again!
Old Mar 1, 2026 | 01:47 PM
Kitc2246's Avatar
Kitc2246
Its been years but somewhere there is a template for adjusting the headlights based on parking a specific distance from a wall or the garage door.
Old Mar 1, 2026 | 07:17 PM
srb1194's Avatar
srb1194
I did find a You Tube video that may be helpful. I just can't figure out how or why they got out of adjustment. I can get the tool and give it a shot.
Thank you.
Old Mar 1, 2026 | 07:56 PM
Kitc2246's Avatar
Kitc2246
If the headlight buckets were removed for any reason make sure they are locked.
Old Mar 1, 2026 | 08:00 PM
srb1194's Avatar
srb1194
They were removed for the PPF replacement but this was done by a shop that specializes in Porsche. The lights appear to be fully flush with the fenders. I thought once they were pushed in firmly they snapped to lock but I’ve never taken them out myself.
Old Mar 2, 2026 | 03:40 PM
Darkly-Noon's Avatar
Darkly-Noon
Here's a (very) detailed procedure from Daniel Stern Lighting you can do yourself. The trick is to find a level surface next to a vertical wall, not always easy since most pavement slopes away from buildings for water drainage
https://www.danielsternlighting.com/tech/aim/aim.html
Old Mar 2, 2026 | 08:14 PM
Kitc2246's Avatar
Kitc2246
I would definitely find the cam lock tool that should be in your tool kit and double check that the cams are locked. I would unlock and then lock. It takes considerable force but then there is a perceptible pop when they lock. I bought a larger tool with more leverage. It doesn't happen too often but I've seen more than one headlight bucket at the track.
Old Mar 2, 2026 | 08:22 PM
srb1194's Avatar
srb1194
Well that's great information there. I guess I was overly paranoid about messing up the PDLS actuators. Luckily I have perfect spot at home to do the alignment. I guess I'm still baffled how they got out of adjustment to begin with.
The shop that removed them has agreed to look at it with me so I'm going to see how that goes first.
Thanks again for the information!
Old Mar 25, 2026 | 09:26 PM
srb1194's Avatar
srb1194
Hey guys, I finally got this project done. Thanks for all the input. If it wasn’t mentioned before the screw is a 5 mm ball. I’d recommend a long tee handle wrench but a standard 5 mm wrench will work, it’s just more aggravating.
