Caliper Rebuild all 4 corners
Is there a comprehensive rebuild guide on these calipers and a good source for the OEM supplier parts. Easy enough to get on PET and buy the stuff from Porsche but throwing everthing in the cart over at Sonnen was going to rack up $450 for all the stuff that I "think" I need and want. Never rebuilt these before, have tried some others and found the pistons much more difficult to remove than I anticipated.
Lagoons brakes seem to be in real bad shape.
Appreciate any guidance with any of this...
crazy money if you need new pistons.
https://www.paragon-products.com/Bre...-kits-late.htm
http://www.pelicanparts.com/techarti...e_Calipers.htm
Caliper rebuild
https://centricparts.centriccatalog....&uid=ANR&sid=0
And here's a great youtube video for the rebuild process. From my experience when you use the clamps and compressed air to remove one piston at a time you must prevent the piston from recoiling back toward the caliper bore as it can easily damage the caliper bore....so you want to catch the piston with a bunched up rag as a catch basin rather than anything that has more cushion / springiness to it.
+1 on the centric parts source. More than likely you won't need new pistons, just dust seals and wipers.
Something to consider - the calipers have wastage/oxidation issues under the spring plates. You'll know this when you take a look at the plates - they will be 'swelled' out from the caliper body.
Be sure to use heat to help remove the spring plate mounting screws - they're held in with red type locktite and are a b!tch to remove (may likely strip the head out without heat). I bought new spring plate screws from McMaster-Carr for pennies. Do some looking on eBay for bleed screws and dust caps.
A good cleaning and powdercoating with the reassembly they'll look great no doubt.
I did a write up a while back, might answer some questions.
If you can afford the down time hold off on ordering new pistons, more than likely you won't need them. Good luck.
https://rennlist.com/forums/944-turb...s-updated.html scroll down to post #11.
Thanks Everyone that was ALL good information. Have not compared prices but this website seems to have it all brake related.
https://www.zeckhausen.com/catalog/
Im armed and dangerous once again.
Rear calipers
Centric seal kit for 968 rear calipers
In case you didn't notice the write up in the link from my previous post, you'll want to scroll down from the top...post #11.
Jay,
Those calipers look awesome. Thats lots of hard work. Did you bead blast the calipers and then spray or have powder coated?
I think Lagoon is destined for a really good functional rebuild, cant have the calipers looking better than the body!!
I may need to buy two new spring plates as there are two that seem slightly bent out enough to overlap the dust seals. Difficult to get dust seals out and see no way to put new ones in without fixing that problem. Other than that the disassembly and cleaning is under way and looking better than anticipated. Looks like no pistons will be needed.
Anything I get from McMaster comes in a box of 20. They are a really good source other than the Costco bulk purchase of it all. Usually turns out I can buy a box of 20 for about the same as buying one from the Porsche.
There are a lot of expensive parts on these calipers if your not careful. Those springplate kits are $38 each (two per caliper) the rebuild kits are $35 each. As Thomas pointed out if you need pistons then grab your wallet at about $50 each. I need all those dampers as somebody has just tossed them all?? $15-20 per caliper.
As noted in prior threads, corrosion under the plates will inhibit the pads ability to retract properly.
I would research what type of 'micro-encapsulation' is used on the OEM plate screws. I would assume it is stronger than red loctite.
John, are you experiencing any specific symptoms that tell you your calipers need to be rebuilt? Or are you just doing the job as part of maintenance? Thx
John - I had my calipers bead blasted then powder coated afterward.
I think you can recover the spring plates. They're SS, so they'll clean up easily (I used a combination of acetone and steel wool to give 'em a good scrubbing to remove the rough stuff then I used Neverdull to finish em to a nice polish). If they appear to be swelled out, I'd put the plate on a 2x4 and cover the other side with a paint stir stick and whack the crap out of it with a dead blow - repeat as needed.
Jeff, the calipers had been removed and were hanging by wire because the rotors were so swelled with rust the car would not roll. I figured it was needed before I put any money and effort into rotors and pads. Not too expensive or difficult if you dont need pistons.
