A/C Compressor replacement
I have a 95 968. The current compressor has an R-134 designator on it.
I ordered a replacement which says fit a 92-95. However, it is designated an R-12 on the case. Can I use this one by changing out lubrication? Or do I need an R-134 compressor?
A compressor is nothing but a refrigerant pump, and many R12 have been successfully converted to R134 including one of mine. But if I were replacing the compressor on my '93 I would prefer a unit originally designed for 134.
Was this compressor new? If so I'm curious, from where?
If it is filled with 12 oil, getting it completely flushed (to the point of dry) without disassembly is difficult.
I *think* that the compressor cares not what it is compressing as it is just a gas anyway until the gas passes through the condenser where it becomes a liquid, then passes through the evaporator where is is returned to a gas, removing the latent heat of vaporization - making you happy.
That being said, conversion from R12 to R134 typically requires replacement of the dryer and the o-rings that make up the sealing connections in the system IIRC.
The primary differences in R12 and R134 are 1) R134 is environmentally friendly, 2) R134 is more widely available, and 3) R12 *seems* to have a lower evaporation temperature/heat capacity (based on my calibrated thermal appendages).
Drain all the oil out of the new compressor.
Put in PAG46 oil, about 5 oz should be safe.
Put in a new drier as well.
The coupe I bought earlier this year had an R134a conversion done by a noted midwest Porsche indie. When the compresor is engaged at idle the engine vibrates quite a bit. I wonder if he used the R12 weight when charging.
