Best way to clean/lube door locks?
I have my passenger door lock apart awaiting replacement parts and thought it would be a good time to clean and lube everything. I was going to use WD-40 to clean everything up then apply graphite to everything but it appears there is some sort of grease in there now. It's mostly dirt now but I wasn't sure if there was some different lube for the actual door lock cylinder?
It's amazing how dirty those locks and internal areas get dirty even being on the inside of the door with seals!
