Pics of solid rear torsion carriers installed
I put these on the car last Sunday. Rear solid torsion carrier mounts. Both were pretty easy to install and it is amazing the amount of rubber they replace. Everything else back there is still stock. I sure would like to get some Racer's Edge equipment back there but it is an investment!
I've given my car (which is primarily going to be a track car, but still streetable) the full Racers Edge treatment - solid/spherical bushings everywhere, camber plates, heavy duty (emphasis on the heavy!) front A-arms, along with Moton Clubsport two-way adjustable shocks/struts, rear torsion bar delete, and much stiffer springs (700 lb up front, 1000 lb in back). Also Enkei NT-03 18" wheels with Hankook R-S3 tires. It's going to ride like a cement truck, but hopefully stick like glue in the turns. Project is nearing completion, after nearly two years(!).
