968 Forum 1992-1995
Manual transmission fluid change questions
Old 03-15-2013, 08:21 PM
NineFiveWon
NineFiveWon's Avatar
Originally Posted by ernie9468
Maybe you should try Red Line 75W90 NS all-synthetic formula A in there,personally this is what I've been running with for over a year now without issues, and shifting is very very smooth.Mine is a 93.
Just to oil I was about to order. Just curious, does anyone know the oil capacity of a 968 transaxle? I'm about to order, I need to know how many QT's!
Cheers!
Old 03-15-2013, 08:41 PM
bombfactory
bombfactory's Avatar
Supposed to be 3 quarts. I just bought some Mobil 1 75-90 at AutoZone.
Old 03-15-2013, 09:58 PM
ernie9468
ernie9468's Avatar
Talking
Cheers!
0.73 U.S. gal or 2.75 liters so three quarts should do the job with maybe a little left over.
Old 04-03-2013, 12:52 AM
JDS968
Bannana Shine
JDS968's Avatar
I use Mobil Delvac 75W-90, which is supposedly much superior to other synthetic gear oils including Mobil 1 75W-90, and also supposedly used in the Porsche 997 RSR transaxles. For what its worth. $42.50 per gallon from Lufteknic.com.
In order to get the whole car on jackstands, I lift using the jacking points, and place jackstands under the semi-trailing arms in the rear (as far inboard as possible) and under the lower A-arms in front (again, as far inboard as possible). I find that this holds the car VERY securely and evenly on all four jackstands, as it is still slightly suspended, rather than sitting directly on the unibody.
To fill the transaxle, I use a Harbor Freight Multi-Use Transfer Pump, item number 66418. At $8 each, you can get one and dedicate it JUST to gear oil, which is nice because you don't want this stuff contaminating ANYTHING else you fill up, ever. In fact, buy a couple of them at a time, can't hurt.
Quick Reply: Manual transmission fluid change questions
