Anyone converted open to LSD?
Try adding some torque to the flange bolt at the back. You just have to remove the driveshaft to get access. I'd do 1/8 of a turn and see if that helps. Mine made noise under coast and I fixed it by adding a shim behind the pinion bearing.
I converted my trans to an OEM (rebuilt) clutch style LSD. Had it in for 2 years, 25 track days and still going strong. It made a massive improvement, both in terms of push out of corners and stability. I used to often spin on one particular corner frequently, but no problem anymore with LSD.
The best type to get is the Modena one, made here in Oz. I think it goes by a different namein the USA.
http://www.modenaengineering.com.au/
