968 piston specs
968 piston specs
Im in the process, will be soon, of adding a stroker crank and doing a 104mm bore on my 928s4. For those in the know,...What is the piston compression height on a 968 piston. The height from the center of the wrist pin to the top of the piston.
thanks <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
