968 Transaxle Gear Ratios
Anybody have the factory manual information regarding the stock gear ratios of the six forward gears, the differential ratio, and the final drive ratio?
Wish I had the 968 manuals! - Anybody selling a copy of the set? If there are several options (like the 951 transaxles) please list them also. Thanks in advance for the information! |
From the owners' manual in my '94 coupe, starting with 1st:
6 speed manual: 3.182 :1 2.000 :1 1.435 :1 1.111 :1 0.912 :1 0.778 :1 Reverse is 3.455 :1 Axle ratio is 3.778 :1 For the Tiptronic: 3.152 :1 1.719 :1 1.222 :1 0.907 :1 Reverse is 2.882 :1 Axle ratio is 3.250 :1 To get final drive ratio, multiply the ratio for the gear you're interested in times the axle ratio. Looking at the axle & 1st gear ratios enlightens me considerably about why the Tip has a reputation for being a bit slower off the line than the 6-speed. Somewhat less torque multiplication there. Jim, slowly crawling into awakefulness.... |
Jim,
Thanks for the information! |
