Couple questions.
OkRider
Couple questions.
I installed a new turn signal relay, now it blinks slow on right and fast on left. Bad relay? What do you guys think? Next question, since I can't find the workshop manual I downloaded, I am replacing my hatch latches since the rubber inserts are toast and don't appear to be sold separately. It seems to me I should leave the posts as they are, install the latches loosely so that they find their natural center then final tighten nuts, then adjust the coupling nut so that both latch collets open and close the same. Is this correct?
Doug.
Doug.
OkRider
I just downloaded it again. I' ll see if I can find it.
OkRider
DOH! I should have known that. Slightly corroded bulb. Fixed, sorry.
