968 Forum 1992-1995
Freakin' hood badge
Old 06-15-2010, 05:37 PM
John Etnier
John Etnier's Avatar
Default Freakin' hood badge
I've had a 'spare' hood badge on hand for years and finally decided it was time to install it, given the beat condition of the original. I had to destroy the original to remove it: nut/post fitting was stripped so I couldn't get the nut off.
Well, the replacement badge is different: much more rounded than the real one, which is practically flat. The rubber gasket supplied with the new badge cannot be made to fit the badge, either: too small. BOTH badges have the same part number!
Sunset is shipping me a new one, cost over $100.00, but I worry: will I have the same problems???
Old 06-15-2010, 05:40 PM
ramius665
ramius665's Avatar
I've done this on both the 968 and the 951, it isn't ever fun.
Old 06-16-2010, 04:28 AM
mattipuh
mattipuh's Avatar
mine got stolen few months ago - planned to replace P-crest with our club emblem.
Old 06-16-2010, 09:04 AM
John Etnier
Bumping: any concrete assistance with this issue much appreciated. Also: if you have an old-style flatter badge in excellent shape (with gasket) to sell, please get in touch with me.
Thanks!
Old 06-16-2010, 10:36 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Very common PITA complaint across all forums.
Some people place the new gasket in very hot water to help make it pliable prior to installation.
Some people will place blue masking tape on the corners of the rubber gasket and 'pull' on the tape to help stretch the gasket onto the badge during installation.
Some people just give up and reuse the old gasket.
A search of the forums (I know it's come up in 993 forum) will provide grief counseling.
Old 06-16-2010, 11:25 AM
Holicow
Holicow's Avatar
I'm sort of glad it is not just me. I thought I had lost all mechanical ability when I could not make the gasket fit all the way around. I'm sure it was funny to watch, pull one side out, the opposite pops out of place, (repeat about 50 times). I just gave up and left the top under the edge, it's not noticeable too much.
Old 06-16-2010, 11:40 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
https://rennlist.com/forums/993-foru...st-gasket.html
Old 06-16-2010, 01:29 PM
John Etnier
Thanks all. None of the threads and discussions here and in PM's I've been sent reference the completely different profile of the 'new' badge, which would not seem to lay flat on the hood.
Anyone else running into this?
Old 06-16-2010, 01:43 PM
Jfrahm
Jfrahm's Avatar
I've always used the inexpensive repro crest and have not had a fitment problem. Heating up the gasket helps, I also tack the gasket to the badge with some contact cement. A credit card to the like can help get the gasket to lie properly on the panel when installing.
Some people forgo the nuts and instead glue the crest down, if someone tries to steal it they do less damage in that case. Naturally you'd need a crest that fit flat or could be formed to fit properly.
-Joel.
Old 06-16-2010, 03:49 PM
JDS968
Bannana Shine
JDS968's Avatar
How often do people try to steal Porsche crests? I thought it was mostly just Tri-Stars, Leapers, Spirit of Ecstasy...Ecstacies...Spirits of...whatever. Stand-up badges, rather than flat ones.
Old 06-17-2010, 04:03 PM
Chaos
Chaos's Avatar
Liquid nails ! Try it.
Old 06-19-2010, 04:31 PM
mattipuh
mattipuh's Avatar
dunno. this was first one stolen from me, so three years it was in it's place.
Old 06-20-2010, 04:24 PM
notthd
notthd's Avatar
John- I have two. one from 92 one 93. I'll look at them as soon as I get back in town on this friday.
Cheers, Mike
Old 06-20-2010, 05:41 PM
John Etnier
Thanks Mike: hope to hear from you via PM.
Old 06-20-2010, 09:51 PM
FRporscheman
FRporscheman's Avatar
Replacing the badge is a PITA. My issues are with the gasket being too small as well. I figured out the blue tape trick for myself and it works great! Don't over-tighten those stupid little nuts.
Quick Reply: Freakin' hood badge
