968 Forum 1992-1995
Mobil 1 fans
Old 10-29-2009, 05:58 PM
FRporscheman
FRporscheman's Avatar
This is my logic: Oil is meant to lubricate. If you add anything to the oil that is not lubricant, you will hurt something. The oil stabilizer stuff looks like it just makes the oil mucous; if you want thicker oil just use thicker oil. Kragen has 60wt valvoline, you can mix it in to make your oil thicker.
BTW, on the Walmart sale:
My local walmart has the mobil 5qt jug for $22.00. You can get Castrol Syntec for $21.87 which looks like their regular price. I go with Castrol Syntec anyway so I was happy to see that, and I bought some. Thanks Miles, you saved me a few bucks!
Old 10-30-2009, 11:16 AM
ryan@usaimage.com
ryan@usaimage.com's Avatar
I would not run 10w-40 in a conventional oil. Too big a spread in viscosity. You can get away with it in a synthetic with no problem. My $.02
Old 10-30-2009, 04:16 PM
StewHatch
StewHatch's Avatar
I was informed that our cars require a specific zinc additive (ZDDP?). You can buy it separately to add during an oil change, or you can use an oil that already contains this. IIRC that short list includes Royal Purple. There are probably additional brands but I can't remember any of them at this time. I've been using Royal Purple ever since with excellent results.
Old 10-30-2009, 08:37 PM
CurtP
CurtP's Avatar
Please qualify this statement. Do you have factual information or is it your opinion that you're getting excellent results?
Old 10-31-2009, 12:11 AM
StewHatch
StewHatch's Avatar
My opinion. Car just runs better and feels smoother since I switched oils. I cannot explain it any better than that. To me, that is an excellent result.
Old 10-31-2009, 02:38 PM
Miles968
Miles968's Avatar
I have not tried this yet, but the bottle says Wal-mart will also take and dispose of the used oil too! For me this is alway been a messy and troublesome step.
Old 11-01-2009, 08:22 AM
FRporscheman
Amsoil also has zinc. And IIRC mobil recently (last year or two) took the zinc out of their formula - I'm not 100% sure but I think so.
Old 11-01-2009, 05:40 PM
Miles968
Miles968's Avatar
Found this informative and just wanted to share: http://www.aa1car.com/library/api_mo...ifications.htm
The lobes on this 289 Ford Mustang flat tappet cam suffered excessive wear because the motor oil did not contain adequate levels of ZDDP anti-scuff additive.
If you are driving an older classic muscle car or hot rod that has an engine with a flat tappet camshaft, you should be aware of the fact that today's "SM" rated motor oils contain much lower levels of anti-scuff additive called "ZDDP" (Zinc Dialkyl Dithio Phosphate). The level of ZDDP in current motor oils has been reduced to no more than 0.08% phosphorus to extend the life of the catalytic converter. Phosphorus can contaminate the catalyst over time if the engine uses oil, causing an increase in tailpipe emissions.
The lower ZDDP content is not harmful to late model engines with roller lifters or followers because the loads are much lower on the camshaft lobes. But on pushrod engines with flat tappet cams, the level of ZDDP may be inadequate to prevent cam lobe and lifter wear. In some cases, cam failures have occurred in as little as a few thousand miles of driving! This is even more of a risk in engines if stiffer valve springs and/or higher lift rocker arms are used.
To avoid such problems, you should add a ZDDP additive to the crankcase, or use an oil that meets the previous "SL" service rating, or use diesel motor oil or racing oil that contains adequate levels of ZDDP to protect the camshaft and lifters.
If you are installing a new camshaft in the engine, be sure to use the cam manufacturers assembly lube and follow the recommended break-in procedure. But you will still need to add ZDDP to the crankcase or use an oil that contains adequate levels of ZDDP for continued protection.
Old 11-01-2009, 08:22 PM
CurtP
CurtP's Avatar
Some formulations have reduced amounts of zinc dithiophosphates, some have had it added back. Zinc dithiophosphates aren't the ONLY anti-wear additives either, so just because it has reduced amounts, doesn't mean it isn't any good.
Oil analysis is the only way to find out if a particular oil is protecting properly.
Old 11-01-2009, 10:04 PM
333pg333
333pg333's Avatar
There is soooo much info on this subject available. Suffice to say, don't use M1 or any
low viscosity oil in our motors. The fact that M1 has recently decided to re introduce
sufficient quantities of ZDDP back into some of their products speaks volumes.
There's a very good (long) oil thread on Pelican. Worth a read.
Also watch out for too high detergent quantity.
Old 11-02-2009, 08:56 AM
Miles968
Miles968's Avatar
I think this is the Pelican link?:
http://www.pelicanparts.com/techarti...il_article.htm
I received this response from Mobil 1 today:
The Mobil1 15W50 contains 1200ppm of ZDDP, formulation information is considered proprietary and not available.
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL -MJ
Old 11-02-2009, 01:00 PM
Sears968
Sears968's Avatar
So is 1200 ppm sufficient? How does this compare to that of Amsoil, etc?
I ask as I currently have M1 15w-50 in my 968.
Thanks,
Old 11-02-2009, 01:12 PM
Miles968
Miles968's Avatar
I wish I could tell you for sure......
The label does indicate a "SL" service rating which in theory is adequate wear protection.....
I guess someone could call and ask?
Old 11-02-2009, 03:01 PM
FRporscheman
Lots of good information, thanks guys.
Quick Reply: Mobil 1 fans
