Where's the door harness plug??
Does anyone know if there is a door wire harness plug on a 968 coupe? Or does the wire harness have to be pulled through the door hole to remove the door. Thanks!!
Kevin
Kevin
It's way up at the very top of the kick panel, almost right under the fusebox. On my car there were two of those flat rectangular plugs, I think one had 8 pins and the other had 10.
I got to it from below. I moved the cruise control computer (or whatever that aluminum box was...) out of the way. I'm not 100% sure, but I think I considered getting to it from above, but after moving the fuse panel I decided it was easier from below.
On the passenger door, I had to disassemble the plug itself in order to remove the door mirror. Fun fun fun, even more fun, then some fun getting it back together properly.
