Difference between water pumps
I can't speak to the part numbers but Pete from RS barn did a great discussion on the 968s at the celebration and touched on water pumps. Apparently the original water pump had a plastic impeller. This impeller sometimes fails. The newer pumps that he uses have a metal impeller. Now the rated flow is not as high as the plastic but they have seen no difference in performance in many installations and feel better about the metal impeller.
I don't have PET handy but if you are referring to the difference between 951 water pump and 968 water pump, then one of the ports is blocked in a 968 water pump that is used on a 951. That is to connection to the coolant hardpipe on a 951.
Raj
Raj
No the 104mm blocks are different from the 100mm blocks so the pumps are different.
I'm comparing the 968 pump with the S2/2.7l pump.
Those blocks are equal so I cannot see why the don't share the same pump.
I don't know what the difference is. I've taken apart a 2.7, a 944S2, and 968 engine and all the waterpumps looks the same, but i didn't look very closely I guess. I still have all of them, I can go compare them if you wish...
Raj, you got it. The 2.7, S2 and 968 pumps I took off all had a "2.7" casting near the upper right.
I just ordered a new 968 pump last week for my other car and like Thom's it had no number at all. The impeller is the same size as the old "2.7" pump though.
Raj, are you saying that a lot of cars (mine included) that are running 3.0 turbos with 968 waterpumps are infact not getting the correct flow round the system if they are not using a 951 waterpump with the 951 watercooling manifold for the turbo?
The bypass Raj refers to is for the watercooled tubocharger--there's a small thermostat in the 951 water pump plastic housing (white rather than black), a crossover hard pipe and then an electric pump (to circulate for a short while after the motor is shut down), and other plumbing from the turbo to the coolant reservoir.
The overall body of the 2.5 & 2.7 water pumps is the same. The impeller is larger for the 2.7's and the receiving surface on the block is different to account for the different sizes of the impellers.
FWIW, I thought the -X meant the pump was rebuilt.
But the question is why there is 2 different 2.7l pumps.
The plastic impeller might be it, or the different cam belt tensioner. Any other thoughts?
My PET shows a supercession for both engines to the 944-106-021-24 number pump.
Supercessions may mean an improvement (seems unlikely for a model 15 years out of production) or just a new supplier (would seem more the case).
somewhere in 1994 the 968 waterpump got a bigger turbine wheel so it gets more water around ,I know becausse I put such a bigger pump on my 1990 951 and you have to grind down the engine block a few mm to make it fit.
Ok so I need to drill out the extra next on my waterpump to get the turbo watercooling system to work properly.
