968 Forum 1992-1995
Video from my 968 after engine rebuiltw RSBARN mods
Old 11-21-2008, 10:49 PM
  #31
z851@yahoo.com
z851@yahoo.com's Avatar
What about the torque tube? Could it be time for a rebuild?
Old 11-22-2008, 09:48 AM
  #32
sergiomartins
sergiomartins's Avatar
Well, the only thing that comes to mind is indeed the Torque Tube, what are the sympthoms of a bad tt, anyone heard of a bad tt doing this type of vibs?
Old 11-22-2008, 10:26 AM
  #33
PorscheDude1
On the Radar
PorscheDude1's Avatar
If the vibrations are there, with the car in neutral and not moving, I would say it is not the torque tube.
Old 11-22-2008, 10:29 AM
  #34
PorscheDude1
On the Radar
Originally Posted by 968TurboS
Could you please tell us in detail what was done to rebuild the engine? Were all parts marked and used in their same locations?
Raj
Here is what he said in his previous post, I guess you missed the link in post #1
Originally Posted by sergiomartins
Hello, im the proud owner of a 1994 968 with 110.000 miles, Although lately im having serious probs with shaking and constant vibration from the engine.
#1 I can feel the vibration in the shifter and siting in the driver seat or against the body
#2 The vibration can be felt with the Clutch pedal In or Out
#3 Vibration is always there like the engine is runing rough, can be felt through out the whole rpm range
#4 If i put my hand on the crossmember, A-arms, Front sway bar is smooth as silk. No vibes there.
#5 With the splindle sleeve that engages into clutch pulled back( not engaged) the vibe is still there.
#6 The car runs fine, with no noticeble loss in power, or Oil pressure and good temps
#7 No codes on the DME, Good voltage power, O2 sensor reads right
Now the parts that were already replaced, and double checked by Porsche garage. All check out
MAF
DMF
Clutch Kit
Timing Belt
Balance Shaft Belt
Ignition Coil
DME ecu
Recheck Timing Marks
Recheck Balance Shaft Marks
Recheck Balance Shafts Orientation Key ways
Variocam pads changed + Chain
Re-time Camshafts
16 Lifters
Lambda Sensor O2
2 x Motor Mounts (original Porsche)
Rod Bearings changed
Exhaust mounts
Spark Plugs Wires Set
Spark plugs
Cap+Rotor
As you can see, im getting pretty desperate, after searching all forums i could find still no solution. Any new ideias?
Old 11-23-2008, 12:33 AM
  #35
FRporscheman
FRporscheman's Avatar
The TT motion is independent of car motion. It only depends on whether the clutch is in or out.
This means it is definitely not the TT.
I still say it's the BSs.
Old 12-05-2008, 04:13 AM
  #36
FRporscheman
What's the word?
Old 12-05-2008, 02:59 PM
  #37
StyleLab
StyleLab's Avatar
exhaust harmonics? I had this problem on an S2 after removing the cat and replacing with a test pipe.
Old 04-22-2009, 01:47 PM
  #38
Damian in NJ
Damian in NJ's Avatar
Did this shaking/vibration ever get resolved after the engine 'rebuild?'
Quick Reply: Video from my 968 after engine rebuiltw RSBARN mods
