968 Forum 1992-1995
Brey-Krause Lower Chassis Support Brace for 968
Old 06-09-2005, 03:43 AM
cooz
cooz's Avatar
Default Brey-Krause Lower Chassis Support Brace for 968
Anyone have any opinion / experience using the Brey-Krause Lower Chassis Support Brace on a 968?
cooz
95 993 C2
94 968 for track/race
Old 06-09-2005, 05:31 AM
Thom
Thom's Avatar
"Damian in NJ" has one on his cab.
You may find a related topic if you use the "Search" function.
Old 06-09-2005, 02:51 PM
Damian in NJ
Damian in NJ's Avatar
It's pricey, but worth it if you have a cab. With that and the Dynatech strut tower brace I had to adjust my rear anti roll bar because the front was biting so well. It wouldn't be my first mod, though-get the mo30 sways and the CS steering wheel first.
Old 06-10-2005, 09:03 PM
cooz
cooz's Avatar
Damian.........how much is it?
Old 07-07-2013, 01:06 PM
mikew968
mikew968's Avatar
Old post...but any new experience here? Would it stiffen the front? Would that cause additional understeer or help keep the chassis square and true? I get a sense I am getting a lot of twist in the chassis as it ages. Also, any experience with the rear torque tube delete kit?
Thanks, Mike
Old 07-07-2013, 07:44 PM
pontifex4
pontifex4's Avatar
I have one from another manufacturer that I would sell, if anyone's interested.
Old 07-07-2013, 10:07 PM
thingo
thingo's Avatar
I found it made a lot of difference, yes it did cause additional understeer, but to me that means it is making a difference to the stiffness of the car, the understeer can be fixed in other ways.
Old 07-11-2013, 10:48 PM
mikew968
mikew968's Avatar
low speed understeer or high speed us?
Old 07-12-2013, 06:41 AM
thingo
thingo's Avatar
I guess I would call it high speed, I don't mind a bit but the brace made it excessive. It has never been as noticeable with my 951
Old 07-12-2013, 04:48 PM
JimV8
JimV8's Avatar
I searched but no luck, anyone have a pic?
Old 07-12-2013, 05:22 PM
RajDatta
RajDatta's Avatar
http://www.bkauto.com/R_1524_Front_C...8_p/r-1524.htm
Old 07-27-2013, 12:38 PM
Stephenwz968
Stephenwz968's Avatar
I too have one on my cab, it does make a big difference in the flex.
Old 07-27-2013, 01:12 PM
flwbyu
flwbyu's Avatar
The one things I have not heard mentioned, was if you have the underneath panel in the front installed. If so, you will either have to remove it or cut into it to get this Brey-Krause Lower Chassis Support Brace to fit correctly.
Old 07-28-2013, 10:00 AM
RajDatta
RajDatta's Avatar
Fly, not sure what piece you mention but I had to make no mods whatsoever to fit the brace.
Old 07-28-2013, 03:09 PM
flwbyu
flwbyu's Avatar
986TurboS, I had another brace prior and switched to Brey-Krause Lower Chassis Support Brace. Great brace and definitely worth the money but I had to make a couple of adjustments to make it work for my vehicle. Glad yours worked with no issues.
Quick Reply: Brey-Krause Lower Chassis Support Brace for 968
